Dale Grice Posted Saturday at 11:15 AM Posted Saturday at 11:15 AM Hi all, I have been struggling or having a senior moment with getting a fillet between these two cylinders. Like rubbing a bead of caulk with your finger between them. Any suggestions? Thanks, Dale Quote
SLW210 Posted Saturday at 09:20 PM Posted Saturday at 09:20 PM Welcome to CADTutor! Can you post the .dwg? Quote
BIGAL Posted yesterday at 12:56 AM Posted yesterday at 12:56 AM Going back a few steps looking at your image if you were to draw the two outside circles in 2D, you can add a fillet arc using Circle TTR you need to trim the new circle and trim the existing two circles add the outer edges and so on add the inner tube circles then extrude the outside object as a pline. There may be some way to add the correct fillet to a solid beyond my pay grade some one else will jump in. Quote
Dale Grice Posted yesterday at 11:09 AM Author Posted yesterday at 11:09 AM Hi, Drawing attached. Dale CB&Q water tower hoop lugs v2.dwg Quote
SLW210 Posted 45 minutes ago Posted 45 minutes ago I gave the drawing a look. I am not 100% sure what you are trying to accomplish here, in order to fillet the two cylinders they need to share a common edge(s), the rectangular extrusion you have between them needs to be unioned as far as I know, if that's what you are trying to use, by the way it looks to be two of those. You might have better luck extruding a fillet shape between them and then union that to them. Quote
SLW210 Posted 44 minutes ago Posted 44 minutes ago On 10/31/2026 at 8:56 PM, BIGAL said: Going back a few steps looking at your image if you were to draw the two outside circles in 2D, you can add a fillet arc using Circle TTR you need to trim the new circle and trim the existing two circles add the outer edges and so on add the inner tube circles then extrude the outside object as a pline. There may be some way to add the correct fillet to a solid beyond my pay grade some one else will jump in. The two tubes run at different angles. Quote
