hello all,
i have been doing a prject for school and these week im going crazy because the only thing im mising and cant draw is a tightlywondrope. The ropa has a Width of about 4cm, its lenghte has to be around 80cm., the rope conects to 2 balls one at each onde that are 6 cm raduis(outerball) and the inner one has 3 cm raduis.
also the boudnary lines around the rope are in black with a 1cm offset also. is there anoe aout there that couls show me how its done..
wat i need is wats in the picture below....... cananyonr explain how its done ?
Thank you
http://i155.photobucket.com/albums/s298/macussa/benavente.png
Easy ! draw one loop segment then just use array to copy it as many times as required with the spacing set to the rope width then draw the eyes on each end.
thanks alot used it and worked fin,, after i offset the circle and trimed it , i used an array .. came out fine,,
thank alot
