muck Posted April 27, 2009 Posted April 27, 2009 What does "key not found" mean in AutoCAD 2009 VBA. How do I begin to look for this error. Thank you, Quote
SEANT Posted April 27, 2009 Posted April 27, 2009 That’s typically shown when a routine tries to reference a named object that is not in the pertinent collection. For example, setting an object to a non-existent layer, or trying to insert a block reference with a name that isn’t part of the block table record. Quote
muck Posted April 27, 2009 Author Posted April 27, 2009 Here is my Code" Please help if you see the problem. Public Sub BlkDefAttLayerChg() Dim objAttribs As Collection Dim objAttrib As AcadAttribute Dim objBlock As AcadBlock Dim strAttribs As String '' get the block For Each objBlock In ThisDrawing.Blocks 'strBlockList = strBlockList & vbCr & objBlock.Name 'Next Set objBlock = ThisDrawing.Blocks.Item(objBlock.Name) '' get the attributes Set objAttribs = GetAttributes(objBlock) '' show some information about each For Each objAttrib In objAttribs 'strAttribs = objAttrib.TagString & vbCrLf 'strAttribs = strAttribs & "Tag: " & objAttrib.TagString & vbCrLf & _ '"Prompt: " & objAttrib.PromptString & vbCrLf & " Value: " & _ 'objAttrib.TextString & vbCrLf & " Mode: " & _ 'objAttrib.Mode 'Private m_AttLayerNameOld As String 'Private m_AttLayerNameNew As String 'If objAttrib.Layer m_AttLayerNameNew Then objAttrib.Layer = m_AttLayerNameNew ' Assign new layer name 'Else 'GoTo NextItem 'End If strattribsl = objAttrib.Layer 'MsgBox strAttribs 'MsgBox strattribsl 'NextItem: Next Next End Sub Function GetAttributes(objBlock As AcadBlock) As Collection On Error Resume Next Dim objEnt1 As AcadEntity Dim objAttribute As AcadAttribute Dim coll As New Collection '' iterate the block For Each objEnt1 In objBlock '' if it's an attribute If objEnt1.ObjectName = "AcDbAttributeDefinition" Then '' cast to an attribute Set objAttribute = objEnt1 '' add attribute to the collection coll.Add objAttribute, objAttribute.TagString '***This causes the error 'coll.Add objAttribute End If Next 'return collection Set GetAttributes = coll End Function Quote
SEANT Posted April 27, 2009 Posted April 27, 2009 I made a couple changes to see if it would help matters. There were a couple of things that suggested that the posted code relied on code not posted. For instance, the layer name referenced with m_AttLayerNameNew was never set. In the code I posted I set it to a test layer that I made sure was available in the drawing. Another change I made was to prevent the routine from running the GetAttributes() function with the standard AutoCAD blocks Modes_Space and Paper_Space. Public Sub BlkDefAttLayerChg() Dim objAttribs As Collection Dim objAttrib As AcadAttribute Dim objBlock As AcadBlock Dim strAttribs As String Dim m_AttLayerNameNew As String Dim strattribsl As String '' get the block For Each objBlock In ThisDrawing.Blocks 'Set objBlock = ThisDrawing.Blocks.Item(objBlock.Name) ''''not needed If InStr(objBlock.Name, "_Space") = 0 Then 'Don't process Model and Paper space blocks Set objAttribs = GetAttributes(objBlock) '' show some information about each For Each objAttrib In objAttribs 'm_AttLayerNameNew = "TestLayer" ''''used for testing. Layer must be present objAttrib.Layer = m_AttLayerNameNew ' Assign new layer name strattribsl = objAttrib.Layer 'is this needed if it's already set in m_AttLayerNameNew Next End If Next End Sub Function GetAttributes(objBlock As AcadBlock) As Collection On Error Resume Next Dim objEnt1 As AcadEntity Dim objAttribute As AcadAttribute Dim coll As New Collection '' iterate the block For Each objEnt1 In objBlock '' if it's an attribute If objEnt1.ObjectName = "AcDbAttributeDefinition" Then '' cast to an attribute Set objAttribute = objEnt1 '' add attribute to the collection coll.Add objAttribute, objAttribute.TagString '***This causes the error End If Next 'return collection Set GetAttributes = coll End Function Quote
