Hello
I am trying to add a line or two to an existing .bat file so that it will run a preexisting lsp file. I am not having a lot of success. It doesn’t help that I am unfamiliar with both .bat and lsp files. I am simply trying to reverse engineer them and then add a couple lines.
Currently the .bat file is used to switch profiles (new support paths and new lsp files in the Startup Suite). This portion works:
net use s: \\Server1\Cadd\CompanyStandards\ClientSpecificStandards\Client1
net use t: \\Server1\Transfer
net use u: \\Server1\Upload
set acad_profile=Client1_std
Now what I need is for the newly created profile (Client1_std) to include a lsp file placed in the Startup Suite and then ran. I have tried to add a line like this without success:
if exist \\Server1\Cadd\CompanyStandards\ClientSpecificStandards\Client1\ClientStandards.lsp call \\Server1\Cadd\CompanyStandards\ClientSpecificStandards\Client1\ClientStandards.lsp
or
if exist S: ClientStandards.lsp call S: ClientStandards.lsp
This is not working. Can someone help me?
Thank you
Mike
I can't help you on that appproach..
but have you thought about starting AutoCAD with the switch to run a script on startup, and the script file can load and run a lisp routine.
Thanks for responding CarlB. I'm not sure where to set a switch to run a script on startup - but I think that would still leave me in the same predicament. I don't know the proper code for the script or .bat file to call up the lsp program?
I only know how to run a script at startup, using the /b switch, but that means you need to do it whilst you open AutoCAD. I'm not sure if there's a way to accomplish this whilst AutoCAD is running.
Here's how I ran a script at startup from a .bat file:
start /wait "C:\Program Files\AutoCAD Map 3D 2008\acad.exe" "path/file_name.dwg" /b "path/script_name.scr"
To run a LSP via this method, your script needs to be nothing but a file with a .scr extention and containing:
(c:your_lisp_command)
