angela@TAG Posted January 18, 2008 Posted January 18, 2008 I am unfamiliar with the align command. What are the specifics that make this command work. My hope is to grab individual multi-line text units and align them so they are all left justified to one another. Is this possible and can I use the align command. Quote
ReMark Posted January 18, 2008 Posted January 18, 2008 In plain old vanilla AutoCAD Align works like this: Aligns objects with other objects in 2D and 3. I'm pretty sure this command was not meant to be used in the manner you wish to use it. Quote
PeterV Posted January 18, 2008 Posted January 18, 2008 I don't think you want the align command. It sounds to me like you should make sure the properties of all the mtext are set to left justified and then place them all on a vertical line. Hope I've helped. If I've misunderstood you, sorry. Quote
angela@TAG Posted January 18, 2008 Author Posted January 18, 2008 Is there another command or method to achieve aligning the text? Quote
angela@TAG Posted January 18, 2008 Author Posted January 18, 2008 What is an LSP? I'm not sure how to use this or to apply it in CAD. Quote
lpseifert Posted January 18, 2008 Posted January 18, 2008 A LSP is your friend. Put the two files in Acad's support directory. To load your friend, at the command line type (load "alignit"). Once loaded invoke the lisp by typing ALI. Quote
angela@TAG Posted January 18, 2008 Author Posted January 18, 2008 This is great. Thanks so much for my new friend. Quote
mahahaavaaha Posted January 19, 2008 Posted January 19, 2008 A LSP is your friend. Put the two files in Acad's support directory. To load your friend, at the command line type (load "alignit"). Once loaded invoke the lisp by typing ALI. Hi, might want to change the commandname here as ALI is an alias for DBCONNECT in "out-of-the-box" Vanilla AutoCAD 2008. You could also create a toolbarbutton for it where the command would look like this: ^C^C^P(if not C:ALI (load"alignit.lsp"));ALI; This would work if the ALI wasn't already taken... /Petri Quote
lpseifert Posted January 19, 2008 Posted January 19, 2008 Hi, ^C^C^P(if not C:ALI (load"alignit.lsp"));ALI; /Petri Oops... ^c^c^p(if (not c:ali (load"alignit"));ali; Quote
jkristia Posted November 1, 2008 Posted November 1, 2008 sorry to re-open this old thread, but I'm looking at a similar problem, how to align all text vertically, and the LSP seems to be missing. Can you please re-attach it?, (for now I just modified the X postion in the property, but I would like a command to do this) Thank you very much Jesper Quote
myself Posted November 6, 2008 Posted November 6, 2008 just to say thank you for this pretty usefull routine, thats exactly what some friends here were looking for Quote
chelsea1307 Posted November 10, 2008 Posted November 10, 2008 i just downloaded the lsp and loaded it into acad and this is what i get Command: ali ALIGNIT - Error: quit / exit abort SYSTEM VARIABLES have been reset Command: any suggestions? Quote
mikitari Posted December 1, 2016 Posted December 1, 2016 (edited) to get it work you need to do as in replay #7 to current thread: http://www.cadtutor.net/forum/showthread.php?19523-Align-Command&p=122186&viewfull=1#post122186 1. Add new path in Autocad options, support section 2. Do APPLOAD lisp from this path. Follow command prompts, and a good tutorial on ALIGNIT.lsp lisp you get it here: http://www.cadalyst.com/general-software/autolisp-solutions-aligning-objects-3178 Edited December 1, 2016 by mikitari Quote
ReMark Posted December 1, 2016 Posted December 1, 2016 mikitari: You do realize you're responding to a question posted by in 2008 do you not? If chelsea still hasn't figured it out by now she should consider starting over in a new career. Please don't start dredging up old threads. Quote
mikitari Posted December 1, 2016 Posted December 1, 2016 (edited) Hi ReMark, yes I do. I have been currently digging for a lisp to align blocks, and found ALIGNIT. And it is good. I was lacking some information on how to make it work, even in this thread. I think someone else might need this information in 2016 too, that is why i posted again, and added the link to a tutorial. I apologize if it is a mess. Cheers! Edited December 1, 2016 by mikitari Quote
