flowerrobot Posted April 28, 2009 Posted April 28, 2009 Gday. Im suffering from a problem, where in dcl. i press a tick box, then options are Enabled, then when i push the button below, it does what it needs, if i do either buttons below it (2), you need to press them a few times to work, if i do those buttons first i need to press that top button a few times to work and need to press accept and cancel buttons a few times to work aswell. heres the code the buttons are "odget" "idget" "thkget" any help would be awesome cheers flower (defun pf () (setq pipematerialpreset '("MILD" "SS")) ;protection, if tiles are nil (if (= pipesize nil) (setq pipesize "2") ) (cond ((= masstype "316 S.S.") (setq material "1")) ((= masstype "MILD STEEL") (setq material "0")) ) (if (= flgod nil) (setq flgod " ") ) (if (= flgid nil) (setq flgid " ") ) (if (= flgthk nil) (setq flgthk " ") ) (setq flgthktype 0) (setq toggle 0) (defun flgio () (setq dialo (load_dialog "MainDCL")) (if (not (new_dialog "Flangebox" dialo)) (exit)) ;set up for data ;for pipe size (start_list "pipeSize") (mapcar 'add_list Pipesizes) (end_list) ;for pipe material (start_list "material") (mapcar 'add_list pipematerialpreset) (end_list) ;Pre-set tiles (set_tile "pipeSize" pipesize ) (set_tile "material" material) (set_tile "flgod" flgod) (set_tile "flgid" flgid ) (set_tile "flgthk" flgthk ) (if (or (= flgtype "TABLED")(= flgtype nil)) (set_tile "tabled" "1") ) (if (= flgtype "TABLEE") (set_tile "tablee" "1") ) (if (= flgtype "ANSI150") (set_tile "ansi150" "1") ) (if (= flgtype "ANSI300") (set_tile "ansi300" "1") ) ;what to do settings (if (= toggle 1) (progn (mode_tile "customflgdtls" 0) (mode_tile "flgtype" 1) (mode_tile "flgthktype" 1) ) (progn (mode_tile "customflgdtls" 1) (mode_tile "flgtype" 0) (mode_tile "flgthktype" 0) ) ) (action_tile "stdthk" "(setq flgthktype 0)") (action_tile "outtk" "(setq flgthktype 1)") (action_tile "customflg" "(progn (if (= toggle 1) (progn (mode_tile \"flgtype\" 0) (mode_tile \"flgthktype\" 0) (mode_tile \"customflgdtls\" 1) (setq toggle 0) ) (progn (mode_tile \"flgtype\" 1) (mode_tile \"flgthktype\" 1) (mode_tile \"customflgdtls\" 0) (setq toggle 1) ) ) )" ) (action_tile "cancel" "(setq ok 0) (done_dialog)" ) (action_tile "accept" "(setq ok 1) (setq pipesize (strcase(get_tile \"pipeSize\"))) (setq material (strcase(get_tile \"material\"))) (setq flgod (strcase(get_tile \"flgod\"))) (setq flgid (strcase(get_tile \"flgid\"))) (setq flgthk (strcase(get_tile \"flgthk\"))) (setq flgtype (strcase(get_tile \"flgtype\"))) (done_dialog)") (action_tile "odget" "(setq ok 2) (setq pipesize (strcase(get_tile \"pipeSize\"))) (setq material (strcase(get_tile \"material\"))) (setq flgod (strcase(get_tile \"flgod\"))) (setq flgid (strcase(get_tile \"flgid\"))) (setq flgthk (strcase(get_tile \"flgthk\"))) (setq flgtype (strcase(get_tile \"flgtype\"))) (done_dialog)") (action_tile "idget" "(setq ok 3) (setq pipesize (strcase(get_tile \"pipeSize\"))) (setq material (strcase(get_tile \"material\"))) (setq flgod (strcase(get_tile \"flgod\"))) (setq flgid (strcase(get_tile \"flgid\"))) (setq flgthk (strcase(get_tile \"flgthk\"))) (setq flgtype (strcase(get_tile \"flgtype\"))) (done_dialog)") (action_tile "thkget" "(setq ok 4) (setq pipesize (strcase(get_tile \"pipeSize\"))) (setq material (strcase(get_tile \"material\"))) (setq flgod (strcase(get_tile \"flgod\"))) (setq flgid (strcase(get_tile \"flgid\"))) (setq flgthk (strcase(get_tile \"flgthk\"))) (setq flgtype (strcase(get_tile \"flgtype\"))) (done_dialog)") (start_dialog) (unload_dialog dialo) ) (flgio) (while (not (or (= ok 1) (= ok 0))) (if (= ok 2) (setq flgod (rtos (getdist "\nWhat is the Flanges O.D")2 0)) (flgio) ) (if (= ok 3) (setq flgid (rtos (getdist "\nWhat is the Flanges I.D")2 0)) (flgio) ) (if (= ok 4) (setq flgthk (rtos (getdist "\nWhat is the Flanges Thickness")2 0)) (flgio) ) ) ) Quote
