3dwannab Posted March 16, 2017 Share Posted March 16, 2017 I've wrote a function to select hatches based on their layer layColor patName patScale What I'm missing is getting the DXF data on ssget for the vla-get-backgroundcolor As I'm not sure if this is exposed to the DXF. Any help would be appreciated. Thanks. ; ; Select hatches on same layer & pattern by 3dwannab ; ; v0.1 - 16.03.2017 ; Usage: Select hatch to select other hatches on similar bkgCol color layer patName patScale (defun c:TEST nil (c:QS_HATCH_SAME_Layer_PatternName_PatternScale_Color_&_BkgColor)) (defun c:QS_HATCH_SAME_Layer_PatternName_PatternScale_Color_&_BkgColor ( / ss ssdata layer layColor patName patScale bkgCol) (while (not (and (setq ss (car (entsel "\nSelect Hatch to get same Hatch entities as:\nlayer layColor patName patScale bkgCol: ")) ssdata (if ss (entget ss)) ) (= (cdr (assoc 0 ssdata)) "HATCH") (sssetfirst nil) (setq ss (vlax-ename->vla-object ss)) (progn (setq bkgCol (vla-get-backgroundcolor ss) layColor (vla-get-color ss) layer (vla-get-Layer ss) patName (vla-get-PatternName ss) patScale (vla-get-PatternScale ss) ) (setq ss (ssget "X" (list (cons 8 layer) '(0 . "HATCH") (cons 2 patName) (cons 62 layColor) (cons 41 patScale) (cons 410 (getvar 'ctab))))) (princ (strcat "\n >>> " (itoa (setq len (sslength ss))) (if (> len 1) " items" " item") " selected <<< ")) (sssetfirst nil ss)(princ) ) ) ) (prompt "\n >>> Nothing selected, or please select a hatch ! <<< ") ) (princ) ) (vl-load-com) (princ "\n:: QS_HATCH_SAME_Layer_PatternName_PatternScale_Color_&_BkgColor.lsp | Version 1.0 | by 3dwannab ::") (princ "\n:: Type \"QS_HATCH_SAME_Layer_PatternName_PatternScale_Color_&_BkgColor\" OR \"TEST\" to Invoke ::") (princ) Quote Link to comment Share on other sites More sharing options...
Grrr Posted March 16, 2017 Share Posted March 16, 2017 Alternative solution would be to iterate over the SS, construct a new SS and populate it with the hatches that match the criteria: (defun C:test ( / e bkgColidx SS nSS i ) (and (setq e (car (entsel "\nSelect source hatch: "))) (= "HATCH" (cdr (assoc 0 (entget e)))) (setq bkgColidx (vla-get-ColorIndex (vla-get-BackgroundColor (vlax-ename->vla-object e)))) (setq SS (ssget "_X" (list '(0 . "HATCH")(cons 410 (getvar 'ctab))))) (progn (setq nSS (ssadd)) (repeat (setq i (sslength SS)) (and (setq e (ssname SS (setq i (1- i)))) (= bkgColidx (vla-get-ColorIndex (vla-get-BackgroundColor (vlax-ename->vla-object e)))) (ssadd e nSS) ); and ); repeat (sssetfirst nil nSS) ); progn ); and (princ) ) (vl-load-com) (princ) The above should select the hatches with the same background index color, else you could use a RGB list for comparsion: (setq RGB (mapcar '(lambda (x) (vlax-get (vla-get-BackgroundColor o) x)) '(Green Blue Red))) As for the DXF, perhaps wait for the professor. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted March 16, 2017 Share Posted March 16, 2017 Hi, Have a look at the Xdata of the Hatch object before and after adding background colour. Quote Link to comment Share on other sites More sharing options...
3dwannab Posted March 16, 2017 Author Share Posted March 16, 2017 Alternative solution would be to iterate over the SS, construct a new SS and populate it with the hatches that match the criteria: (defun C:test ( / e bkgColidx SS nSS i ) (and (setq e (car (entsel "\nSelect source hatch: "))) (= "HATCH" (cdr (assoc 0 (entget e)))) (setq bkgColidx (vla-get-ColorIndex (vla-get-BackgroundColor (vlax-ename->vla-object e)))) (setq SS (ssget "_X" (list '(0 . "HATCH")(cons 410 (getvar 'ctab))))) (progn (setq nSS (ssadd)) (repeat (setq i (sslength SS)) (and (setq e (ssname SS (setq i (1- i)))) (= bkgColidx (vla-get-ColorIndex (vla-get-BackgroundColor (vlax-ename->vla-object e)))) (ssadd e nSS) ); and ); repeat (sssetfirst nil nSS) ); progn ); and (princ) ) (vl-load-com) (princ) The above should select the hatches with the same background index color, else you could use a RGB list for comparsion: (setq RGB (mapcar '(lambda (x) (vlax-get (vla-get-BackgroundColor o) x)) '(Green Blue Red))) As for the DXF, perhaps wait for the professor. Thanks for going to the trouble of writing that for me. Is there any way to test how quick a fn is to compare them? But it's always good to start my collection of code snippets. Thank you. Hi,Have a look at the Xdata of the Hatch object before and after adding background colour. Interesting. I have a fn (don't know where, as I've had it a long time) and never used it. ;; get entity list of user picked entity ;; plus related objects (defun c:myentget+ (/ ent elst) (if (and (setq ent (car (entsel "\nSelect entity to list."))) (setq elst (entget ent '("*")))) (progn (textscr) (princ "\n>>>------> ") (princ (vlax-ename->vla-object ent)) (mapcar 'print elst) (mapcar '(lambda(x / slst) (if (and (assoc x elst) (setq slst (entget (cdr (assoc x elst))))) (progn (prompt (strcat "\n\n******* Dump DXF "(itoa x)" listing *********")) (foreach n slst (print n)) ) ) ) '(330 340)) ; '(320 330 340 350 360)) ) ) (princ) ) and checked that. I missed this earlier. So, I've got this portion of data back : (-3 ("HATCHBACKGROUNDCOLOR" (1071 . -1023410170) (1000 . "") (1000 . "")) ("GradientColor1ACI" (1070 . 5)) ("GradientColor2ACI" (1070 . 2)) ("ACAD" (1010 0.0 0.0 0.0))) For the life of me I don't know what to do with it or how to use that in the filter for ssget. My ssget _X now looks like (this is probably way off) (setq ss (ssget "X" (list (cons 8 layer) '(0 . "HATCH") (cons 2 patName) (cons 1071 bkgCol) (cons 62 layColor) (cons 41 patScale) (cons 410 (getvar 'ctab))))) Quote Link to comment Share on other sites More sharing options...
3dwannab Posted April 11, 2017 Author Share Posted April 11, 2017 Never did find a way to get the HATCHBACKGROUND DXF code filtered in the ssget. Just went with this instead with the help of GRRRs code. ;; Select HATCH by: Layer, Pattern Name, Pattern Scale, Colour & Background Colour ;; by 3dwannb on 11.04.17 ;; ;; Help by GRRR: http://www.cadtutor.net/forum/showthread.php?100136-Select-Hatch-by-background-color&p=681038&viewfull=1#post681038 ;; ;; Known Bugs: None ;; (defun c:QS_HLPSCB nil (c:QS_HATCH_SAME_Layer_PatternName_PatternScale_Color_&_BkgColor)) (defun c:QS_HATCH_SAME_Layer_PatternName_PatternScale_Color_&_BkgColor ( / bkgCol layColor layer patName patScale ss nSS ssdata ) (while (not (and (setq ss (car (entsel "\nSelect Hatch to get same Hatch entities as:\nLayer, Pattern Name, Pattern Scale, Colour & Background Colour :")) ssdata (if ss (entget ss)) ) (= (cdr (assoc 0 ssdata)) "HATCH") (sssetfirst nil) (setq ss (vlax-ename->vla-object ss)) (progn (setq bkgCol (vla-get-backgroundcolor ss) bkgCol (vla-get-ColorIndex (vla-get-BackgroundColor ss)) layColor (vla-get-color ss) layer (vla-get-Layer ss) patName (vla-get-PatternName ss) patScale (vla-get-PatternScale ss) ss (ssget "X" (list (cons 8 layer) '(0 . "HATCH") (cons 2 patName) (cons 62 layColor) (cons 41 patScale) (cons 410 (getvar 'ctab)))) nSS (ssadd) ) (repeat (setq i (sslength ss)) (and (setq e (ssname ss (setq i (1- i)))) (= bkgCol (vla-get-ColorIndex (vla-get-BackgroundColor (vlax-ename->vla-object e)))) (ssadd e nSS) ) ) (princ (strcat "\n >>> " (itoa (setq len (sslength nSS))) (if (> len 1) " items" " item") " selected <<< ")) (sssetfirst nil nSS) ) ) ) (prompt "\n >>> Nothing selected or not a Hatch ! <<< ") ) (princ) ) (vl-load-com) (princ "\n:: QS_HATCH_SAME_Layer_PatternName_PatternScale_Color_&_BkgColor.lsp | Version 1.0 | by 3dwannab ::") (princ "\n:: Type \"QS_HATCH_SAME_Layer_PatternName_PatternScale_Color_&_BkgColor\" OR \"QS_HLPSCB\" to Invoke ::") (princ) Quote Link to comment Share on other sites More sharing options...
