Results 1 to 6 of 6
    Senior Member vanowm's Avatar
    vanowm's Computer Details
    Windows 7 SP1 x86/x64
    AutoCAD 2002
    Feb 2015
    124
    Question Cut polymesh with another polymesh?
    Hello.
    I have a polimesh (yellow) that I need to cut with another polimesh (green)
    How can I do that?
    Thank you.
    P.S.
    Using AutoCAD 2002
    AutoCAD 2002 / R13
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,735
    I had no luck slicing your polymesh. I also had no luck converting it to a surface. So I redrew the base geometry using 3Dpolylines which I then lofted to created lofted surfaces at which point I was able to slice the yellow colored object in your drawing. This is the result. It's cyan colored because I drew my new geometry on two different layers with distinctly different colors. Only the result of the slice is depicted.
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,735
    All three pre-slice objects....
    AutoCAD 2002
    Feb 2015
    124
    Unfortunately LOFT is not available in ACAD 2002
    AutoCAD 2002 / R13
  5. #5
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,735
    Did you use EDGESURF to create your meshes originally?
  6. #6
    AutoCAD 2002
    Feb 2015
    124
    No, I use RULESURF
    I have top and bottom splines between which RULESURF was used to create mesh. Later I "unfold" it to make it flat.
    P.S.
    Updated .dwg sample
    AutoCAD 2002 / R13
  1. covert 3d face to polymesh
    By motee-z in forum AutoCAD 3D Modelling & Rendering
    Last Post: 4th Nov 2011, 01:20 am
  2. 3D Polymesh to 2D
    By nocturne00 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 9th Aug 2009, 09:43 am
  3. Subtracting polymesh
    By MantaBase in forum AutoCAD Beginners' Area
    Last Post: 6th Oct 2007, 03:45 pm
  4. Polymesh to 3DFace
    By i-wilson@ntlworld.com in forum AutoCAD General
    Last Post: 9th Nov 2006, 05:13 pm
  5. convert 3d solid to polymesh
    By Totes100 in forum AutoCAD General
    Last Post: 3rd Jun 2004, 09:16 pm
