link a predefined field to an object
  • Replies 29
  • samifox
    14
  • tombu
    6
  • Dadgad
    5
  • steven-g
    5
Posted Images
as you know if you follow my posts,
i have an mtext object carrying a field attached to a Point object,
meaning a field that reading the Y value of that point object,
i was thinking not to use the point but to read its own Y value
is that possible?
I've got code to insert a block that includes a point and attributes for Easting and Northing using fields to get those values from the point.
No way out of having a separate object to reference.
Create one Mtext then a separate Field referencing the Mtext, the copy the value at the bottom of the Field dialog box and paste it into the Mtext? Do you have code to do that?
:thumbsup: No just manually, but then you only need do it once and copy it as needed. I actually just double clicked on the field selected the text (value) then double clicked on the mtext and pasted it in.
  • 2 weeks later...
hi again,
my field reading the Y coordinate of another object, when i convert to a block, it reads another Y.
i assume its reading the block's local Y,
it is possible to let it read the UCS y always?
