Results 1 to 5 of 5
    Forum Newbie
    Architectural
    AutoCAD 2017
    Jun 2017
    3
    Default a software problem has caused Autocad to slose unexpectedly.
    hello,
    I used to have autocad 2013 and then it crashed and then I uninstalled it and kept installing 2015 ..facing the same problem I unistalled all of the software and all the files that are autocad related and installed 2017 and stil I faced the same problem.
    2015 and 2017 are student versions
    Forum Newbie
    Architectural
    AutoCAD 2017
    Jun 2017
    3
    IT would be awesome if anyone could help out.... and I just wanted to add that softwares aren't my strong suit..so It would be awesome if you could be detailed about any given solutions...
    thank you sooooo much
    Senior Member welldriller's Avatar
    welldriller's Computer Details
    Windows 10 Home
    Dell inspiration 3650
    x64 processor
    8 GB
    Dell P190SB#4
    Solidworks 2017
    Jan 2013
    Prince George, Va.
    302
    Hi Saaraharas
    Have you tried turning off your firewall and virus protection and then down load the program?
    DO NOT FORGET TO TURN EVERY THING BACK ON WHEN YOU ARE DONE
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    3D model building, texturing and rendering. Photoshop Color Graphics.
    AutoCAD 2014
    Feb 2006
    Southern California
    10,197
    Quote Originally Posted by welldriller View Post
    Actually, leave the virus protection off until after you install the program, then turn it back on. Also, disable the Windows UAC. These things can interfere with proper software installation by blocking necessary files from being installed.
    Installation Instructions: https://knowledge.autodesk.com/custo...prepare-system
    But before you install, since you have unsuccessfully installed 3 different versions of Autocad, I would recommend you do a clean uninstall and get rid of all Autodesk files.
    Clean Uninstall Instructions: https://knowledge.autodesk.com/custo...lean-uninstall
    All of this is under the assumption that your computer meets or exceeds the minimum system requirements necessary to run the versions of Autocad that you're trying to install?
    System Requirements: https://knowledge.autodesk.com/suppo...r-AutoCAD.html
    CGSociety Portfolio: http://rdeweese.cgsociety.org/
    Facebook:
    https://www.facebook.com/rdeweese67/
    "Work Smart, Not Hard"
  5. #5
    Forum Newbie
    Architectural
    AutoCAD 2017
    Jun 2017
    3
    Hello,
    yes I have tried that... and I have uninstalled it completely and then installed it again...
    I did find the solution though and that is uninstalling .NET FRAMEWORK completely and then I download it again from this link :
    https://www.microsoft.com/net/download/framework
    and it worked ... so I would recommend that as well...
    Thank you so much for your suggestions
  1. IFC file caused problem? Autocad MEP 2013
    By Jessica28 in forum MEP
    Last Post: 24th Oct 2014, 03:16 pm
  2. Autocad 2013 closed unexpectedly ??
    By ica_cici in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 28th Dec 2012, 01:59 am
  3. 2011: Performance issues caused by McAfee anti-virus software
    By Autodesk in forum AutoCAD RSS Feeds
    Last Post: 27th Oct 2010, 12:30 am
  4. 2011: Performance issues caused by McAfee anti-virus software
  5. 2011: Performance issues caused by McAfee anti-virus software
