Results 1 to 4 of 4
    Senior Member Bobzy20's Avatar
    Bobzy20's Computer Details
    Windows 7 Ultimate (x64)
    Advent T9509
    Foxconn G9657MA-8KS2H
    Intel Core 2 Quad Q6600
    8GB DDR2 PC2-5300
    Nvidia Quadro FX580 512MB
    320GB SATA
    WD 1TB SATA
    Advent X19w 19" Monitor
    Electrical
    Bobzy20's Discipline Details
    Lighting Controls CAD Technician
    Electrical
    AutoCAD 2014
    Aug 2009
    Middlesex, UK
    395
    Default Remove all 3DSolids within Blocks Script
    Hi
    Does anybody know of a script for AutoCAD 2012 that will remove all 3DSolids within a drawing even if they are nested within a block/s?
    Any help would be great
    Thanks
    Bob
    Apparently Revit is the FUTURE but all I know is AutoCAD.
    Super Member
    not applicable
    Jun 2016
    633
    This can't be done with a script (*.scr). But a Lisp solution is possible:
    Code:
    (defun c:Test ( / doc)
      (setq doc (vla-get-activedocument (vlax-get-acad-object)))
      (vla-endundomark doc)
      (vla-startundomark doc)
      (vlax-for blk (vla-get-blocks doc)
        (vlax-for obj blk
          (if (= "AcDb3dSolid" (vla-get-objectname obj))
            (vla-delete obj)
    BricsCAD 18
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,131
    Add this before the (princ) to remove other solids
    Code:
    (setq ss (ssget "X" (list (cons 0 "3dSolid"))))
    (command "erase" ss "")
    Advent T9509
    8GB DDR2 PC2-5300
    320GB SATA
    WD 1TB SATA
    Electrical
    Electrical
    AutoCAD 2014
    Aug 2009
    Middlesex, UK
    395
    Thank you both for your help.
  1. Defining 3DSOLIDs in DXF files
    By andycee in forum AutoCAD Beginners' Area
    Last Post: 8th Mar 2015, 09:26 pm
  2. Can't remove bad blocks from my drawing
    By bababarghi in forum AutoCAD Drawing Management & Output
    Last Post: 6th Feb 2014, 10:12 pm
  3. union of 3dsolids
    By Jef! in forum AutoLISP, Visual LISP & DCL
    Last Post: 12th Jan 2014, 02:02 am
  4. Remove Blocks From a Drawing?
    By AQucsaiJr in forum AutoLISP, Visual LISP & DCL
    Last Post: 14th Oct 2009, 02:21 pm
  5. How to add and remove blocks from Design Center?
    By PPCLAR in forum AutoCAD Beginners' Area
    Last Post: 18th Sep 2009, 10:30 pm
