ArjenB Posted October 7, 2017 Share Posted October 7, 2017 My VBA application requires info from one drawing to be used in another one in the same VBA running session. I need to ALIGN one drawing based upon 3 3D points from another draiwng automatically. At the moment I'm running my application to collate the info from drawing 1, store it, close my application to open the other drawing and run my application again to retrieve the info to ALIGN it. Any idea how I can switch to another loaded drawing in the same VBA running session? Thanks! Quote Link to comment Share on other sites More sharing options...
ArjenB Posted October 8, 2017 Author Share Posted October 8, 2017 I've narrowed the problem down: I've created a combobox to switch drawings whilst my application is running and even ACTIVATE and REGEN the selected drawing: ThisDrawing.Application.Documents.Item(ComboBox1.ListIndex).Activate ThisDrawing.Application.Documents.Item(ComboBox1.ListIndex).Regen acAllViewports all works fine, BUT The GETPOINT line is only successful in the drawing that was active BEFORE I started my application and Fails in the other activated drawing: The error I get in all other drawings I select and activate: Anyone any idea what's need to be set before I can use it in the newly activated drawing? Thanks Quote Link to comment Share on other sites More sharing options...
RICVBA Posted October 9, 2017 Share Posted October 9, 2017 I've narrowed the problem down: I've created a combobox to switch drawings whilst my application is running and even ACTIVATE and REGEN the selected drawing: ThisDrawing.Application.Documents.Item(ComboBox1.ListIndex).Activate ThisDrawing.Application.Documents.Item(ComboBox1.ListIndex).Regen acAllViewports all works fine, BUT The GETPOINT line is only successful in the drawing that was active BEFORE I started my application and Fails in the other activated drawing: The error I get in all other drawings I select and activate: Anyone any idea what's need to be set before I can use it in the newly activated drawing? Thanks have you already tested this proposal? Quote Link to comment Share on other sites More sharing options...
ArjenB Posted October 9, 2017 Author Share Posted October 9, 2017 Hi RICVBA, Yep, just tested it, it failed again and replied on the other forum with more details (Watch state). Thanks Quote Link to comment Share on other sites More sharing options...
