ArjenB
Switching to another drawing in a running VBA session
ArjenB
My VBA application requires info from one drawing to be used in another one in the same VBA running session.
I need to ALIGN one drawing based upon 3 3D points from another draiwng automatically.
At the moment I'm running my application to collate the info from drawing 1, store it, close my application to open the other drawing and run my application again to retrieve the info to ALIGN it.
Any idea how I can switch to another loaded drawing in the same VBA running session?
Thanks!
Share this post
Link to post
ArjenB
I've narrowed the problem down:
I've created a combobox to switch drawings whilst my application is running and even ACTIVATE and REGEN the selected drawing:
ThisDrawing.Application.Documents.Item(ComboBox1.ListIndex).Activate
ThisDrawing.Application.Documents.Item(ComboBox1.ListIndex).Regen acAllViewports
all works fine, BUT
The GETPOINT line is only successful in the drawing that was active BEFORE I started my application and Fails in the other activated drawing:
The error I get in all other drawings I select and activate:
Anyone any idea what's need to be set before I can use it in the newly activated drawing?
Thanks
Share this post
Link to post
RICVBA
all works fine, BUT
Thanks
have you already tested this proposal?
Share this post
Link to post
ArjenB
Hi RICVBA,
Yep, just tested it, it failed again and replied on the other forum with more details (Watch state).
Thanks
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
