Designer Posted December 20, 2017 Share Posted December 20, 2017 Hi all, It`s been a while. Does anyone have a lisp to show on a leader the visibility state of a dynamic block? Cheers Quote Link to comment Share on other sites More sharing options...
rlx Posted December 21, 2017 Share Posted December 21, 2017 Just quickly cut-copy-pasted together : ; modified / supplemented lsp found on : [url]http://www.cadtutor.net/forum/showthread.php?39301-Block-into-multileader-text/page2&highlight=leader[/url] (defun c:VisLabel (/ blk entl obj) (vl-load-com) (cond ((not (setq blk (car (entsel "\nSelect block: "))))) ((not (eq (cdr (assoc 0 (entget blk))) "INSERT")) (princ "\nInvalid object!")) ((setq pt (getpoint "\nSpecify first point: ")) (setq entl (entlast)) (vl-cmdf "_.mleader" "_non" pt "\\") (while (eq (logand 1 (getvar 'CMDACTIVE)) 1) (vl-cmdf "")) (if (and (not (equal entl (setq entl (entlast)))) (setq entl (vlax-ename->vla-object entl))) (if (not (setq visname (GetBVis (vlax-ename->vla-object blk)))) (vla-put-textstring entl "No visibility") (vla-put-textstring entl visname) ) ) ) ) (princ) ) ; just some ccp (cut copy paste) from my RlxBlk.lsp ; (GetBVis (vlax-ename->vla-object (car (entsel)))) ; get current visibility name block object (defun GetBVis ( %blk / blk dic bvp bvn) (if (and (vl-every '(lambda (p)(vlax-property-available-p %blk p)) '(isdynamicblock hasextensiondictionary effectivename)) (setq blk (vla-item (vla-get-blocks (vla-get-document %blk)) (vla-get-effectivename %blk))) (setq dic (dictsearch (vlax-vla-object->ename (vla-getextensiondictionary blk)) "ACAD_ENHANCEDBLOCK")) (setq bvp (findaso "BLOCKVISIBILITYPARAMETER" (massoc 360 dic))) (setq bvn (cdr (assoc 301 bvp)))) (vl-some '(lambda (p) (if (= (vla-get-PropertyName p) bvn) (vlax-get p 'Value))) (vlax-invoke %blk 'getDynamicBlockProperties)))) (defun massoc ($i $l / a l)(while (setq a (assoc $i $l))(setq l (cons (cdr a) l) $l (cdr (member a $l))) l)) (defun FindAso ($v %l) (vl-some (function (lambda(x) (if (= $v (cdr (assoc 0 (setq e (entget x))))) e nil))) %l)) gr.Rlx Quote Link to comment Share on other sites More sharing options...
Designer Posted December 21, 2017 Author Share Posted December 21, 2017 Thank you it worked. I tried to change the line where you put to write (vla-put-textstring entl "No visibility") to show when there is no visibility mode to show the block name, i tried (vla-put-textstring entl effectivename) but it didn't work. Can you help me again? Just quickly cut-copy-pasted together : ; modified / supplemented lsp found on : [url]http://www.cadtutor.net/forum/showthread.php?39301-Block-into-multileader-text/page2&highlight=leader[/url] (defun c:VisLabel (/ blk entl obj) (vl-load-com) (cond ((not (setq blk (car (entsel "\nSelect block: "))))) ((not (eq (cdr (assoc 0 (entget blk))) "INSERT")) (princ "\nInvalid object!")) ((setq pt (getpoint "\nSpecify first point: ")) (setq entl (entlast)) (vl-cmdf "_.mleader" "_non" pt "\\") (while (eq (logand 1 (getvar 'CMDACTIVE)) 1) (vl-cmdf "")) (if (and (not (equal entl (setq entl (entlast)))) (setq entl (vlax-ename->vla-object entl))) (if (not (setq visname (GetBVis (vlax-ename->vla-object blk)))) (vla-put-textstring entl "No visibility") (vla-put-textstring entl visname) ) ) ) ) (princ) ) ; just some ccp (cut copy paste) from my RlxBlk.lsp ; (GetBVis (vlax-ename->vla-object (car (entsel)))) ; get current visibility name block object (defun GetBVis ( %blk / blk dic bvp bvn) (if (and (vl-every '(lambda (p)(vlax-property-available-p %blk p)) '(isdynamicblock hasextensiondictionary effectivename)) (setq blk (vla-item (vla-get-blocks (vla-get-document %blk)) (vla-get-effectivename %blk))) (setq dic (dictsearch (vlax-vla-object->ename (vla-getextensiondictionary blk)) "ACAD_ENHANCEDBLOCK")) (setq bvp (findaso "BLOCKVISIBILITYPARAMETER" (massoc 360 dic))) (setq bvn (cdr (assoc 301 bvp)))) (vl-some '(lambda (p) (if (= (vla-get-PropertyName p) bvn) (vlax-get p 'Value))) (vlax-invoke %blk 'getDynamicBlockProperties)))) (defun massoc ($i $l / a l)(while (setq a (assoc $i $l))(setq l (cons (cdr a) l) $l (cdr (member a $l))) l)) (defun FindAso ($v %l) (vl-some (function (lambda(x) (if (= $v (cdr (assoc 0 (setq e (entget x))))) e nil))) %l)) gr.Rlx Quote Link to comment Share on other sites More sharing options...
rlx Posted December 21, 2017 Share Posted December 21, 2017 sure : ; modified lsp found on : [url]http://www.cadtutor.net/forum/showthread.php?39301-Block-into-multileader-text/page2&highlight=leader[/url] (defun c:VisLabel (/ blk entl pt visname) (cond ((not (setq blk (car (entsel "\nSelect block: "))))) ((not (eq (cdr (assoc 0 (entget blk))) "INSERT")) (princ "\nInvalid object!")) ((setq pt (getpoint "\nSpecify first point: ")) (setq entl (entlast) blk (vlax-ename->vla-object blk)) (vl-cmdf "_.mleader" "_non" pt "\\") (while (eq (logand 1 (getvar 'CMDACTIVE)) 1) (vl-cmdf "")) (if (and (not (equal entl (setq entl (entlast)))) (setq entl (vlax-ename->vla-object entl))) (if (setq visname (GetBVis blk)) (vla-put-textstring entl visname) (vla-put-textstring entl (vlax-get-property blk (if (vlax-property-available-p blk 'EffectiveName) 'EffectiveName 'Name)))))) ) (princ) ) ; just some ccp (cut copy paste) from my RlxBlk.lsp ; (GetBVis (vlax-ename->vla-object (car (entsel)))) ; get current visibility name block object (defun GetBVis ( %blk / blk dic bvp bvn) (if (and (vl-every '(lambda (p)(vlax-property-available-p %blk p)) '(isdynamicblock hasextensiondictionary effectivename)) (setq blk (vla-item (vla-get-blocks (vla-get-document %blk)) (vla-get-effectivename %blk))) (setq dic (dictsearch (vlax-vla-object->ename (vla-getextensiondictionary blk)) "ACAD_ENHANCEDBLOCK")) (setq bvp (findaso "BLOCKVISIBILITYPARAMETER" (massoc 360 dic))) (setq bvn (cdr (assoc 301 bvp)))) (vl-some '(lambda (p) (if (= (vla-get-PropertyName p) bvn) (vlax-get p 'Value))) (vlax-invoke %blk 'getDynamicBlockProperties)))) (defun massoc ($i $l / a l)(while (setq a (assoc $i $l))(setq l (cons (cdr a) l) $l (cdr (member a $l))) l)) (defun FindAso ($v %l) (vl-some (function (lambda(x) (if (= $v (cdr (assoc 0 (setq e (entget x))))) e nil))) %l)) gr.Rlx Quote Link to comment Share on other sites More sharing options...
Designer Posted December 21, 2017 Author Share Posted December 21, 2017 Thanks your the best Quote Link to comment Share on other sites More sharing options...
