mahramou101 Posted April 27, 2018 Share Posted April 27, 2018 i trying multiple boundary "bo" some ares give me error ( a closed boundary cannot b determined ) when i cancel and try again the same (error-ed) ares individually or with other ares it perfectely work is this bug or error or i miss something ???? the following indication gif and dwg transfer.dwg Quote Link to comment Share on other sites More sharing options...
mahramou101 Posted April 27, 2018 Author Share Posted April 27, 2018 Quote Link to comment Share on other sites More sharing options...
SLW210 Posted April 27, 2018 Share Posted April 27, 2018 Could be a bug. I got that here as well on your drawing. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted April 29, 2018 Share Posted April 29, 2018 I tried boundary & bpoly no probs. Not sure which is the outer boundary your trying to create, is multipe rectangs then create a pline if so then the convex hull algorithm is probably what you want. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted April 30, 2018 Share Posted April 30, 2018 I tried boundary & bpoly no probs. Not sure which is the outer boundary your trying to create, is multipe rectangs then create a pline if so then the convex hull algorithm is probably what you want. Were you using AutoCAD 2018? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted May 1, 2018 Share Posted May 1, 2018 Slw210 yes CIV3D 2018 need to update my profile. Still not sure about exact boundary required. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted May 1, 2018 Share Posted May 1, 2018 It took me several tries, but I did get that message to show. Maybe just a bug in Vanilla. Quote Link to comment Share on other sites More sharing options...
profcad Posted May 2, 2018 Share Posted May 2, 2018 Years ago, there was an issue if all the objects were not visible on screen, hatching and boundary would fail. They said the problem was fixed. I still get the errors, so now I Zoom extents before using the hatch or boundary command. Also, with the Boundary command, the default selection set is the visible objects in the viewport. If some of the edges are off the screen, it may not find them. You can click the New button for boundary set and type ALL. Quote Link to comment Share on other sites More sharing options...
