hanhphuc Posted May 25, 2018 Posted May 25, 2018 (edited) ;;;............FIND DETAILS OF CIRCLE INSIDE A BLOCK......................... How can I get the present location of the circle.[/quote] if direction normal & 2D circle (1st level nested), try this simple conversion.. [code] [color="green"];vlisp [/color] (defun PtInsideBlock (en p / ob bp l ) (setq bp '(0. 0.) ob (vlax-ename->vla-object en) l (mapcar ''((x) (vlax-get ob x)) (vl-list* 'ObjectName 'InsertionPoint 'Rotation (mapcar ''((x) (strcat x "Effectivescalefactor")) '( "X" "Y" )) ) ) p (mapcar '* p (cdddr l)) ) (if (= (car l) "AcDbBlockReference") (mapcar '+ (cadr l) (polar bp (+ (angle bp p) (caddr l)) (distance bp p)) ) ) ) [color="green"];pure vanilla [/color] (defun PtInsideBlock (e p / bp e l ) (setq bp '(0. 0.) e (entget e) l (mapcar ''((x)(cdr (assoc x e))) '(0 10 50 41 42 )) p (mapcar '* p (cdddr l)) ) (if (= (car l) "INSERT") (mapcar '+ (cadr l) (polar bp (+ (angle bp p) (caddr l)) (distance bp p)) ) ) ) assign en variable (repeat (setq i (sslength xss2)) (setq e(entget (setq [b][color="red"][u]en[/u][/color][/b] (ssname xss2 (setq i (1- i)))))) ... ... ... [color="red"](setq [b]center[/b] (cdr (assoc 10 get))) (princ (strcat "\nCenter = "(vl-princ-to-string ([color="blue"]PtInsideBlock[/color] [b][u]en[/u][/b] [b]center[/b] )))) [/color] ... ... ... minimal tested which supports block with & w/out uniform scale Edited May 25, 2018 by hanhphuc vanilla code added Quote
