Levco101 Posted May 21, 2018 Share Posted May 21, 2018 Have been running 2007 on Win 7 for years. Installed 2007 on a new I7 HP with Win 10 64 pro. It installed and registered in the Win 7 compatiable mode. 2007 runs with administrator and loads a drawing and runs behind a black screen. The command line cursor works, the menus work, but no visual tool tip or cross hairs, the cordinates increase/decrease, etc. Besides Longbow, is there a fix? Thanks, Stan I7-4770 3.4ghz, 8 gig, 1TB Quote Link to comment Share on other sites More sharing options...
pendean Posted May 21, 2018 Share Posted May 21, 2018 Turn off hardware acceleration and see if that helps. Longbow Software's website also offers many other free tips to try that may help without having to buy their fix (kind of nice of them to do that). Quote Link to comment Share on other sites More sharing options...
Levco101 Posted May 22, 2018 Author Share Posted May 22, 2018 Dean: This I-7 4770 does not let me change the Hardware Acc. None of Longbow's tips help. Thanks, Stan correction: I7-4770 3.4ghz, 16 gig, 1TB Quote Link to comment Share on other sites More sharing options...
Dadgad Posted May 23, 2018 Share Posted May 23, 2018 Dean: This I-7 4770 does not let me change the Hardware Acc. None of Longbow's tips help.Thanks, Stan correction: I7-4770 3.4ghz, 16 gig, 1TB Welcome to CADTutor Levco. Just a guess, I have never used Longbow, nor Windows 10, am still using 8.1, but Longbow does have a good track record for dealing with just these sorts of issues through the years. I think that having exhausted all of their non-pay suggestions (which is very nice of them:)), that it might be a good time to reach out to them through their contact link, and ask if they are aware of any paying users, for whom Longbow has solved a similar issue, specifically with Windows 10. Were you able to open OPTIONS, and look on the SYSTEM tab, for hardware acceleration? The Hardware Acceleration setting you should be looking for is within Autocad, as described on the SYSTEM tab. At least that is where it is nowadays. I am not sure about 2007, I started on 2009. Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 23, 2018 Share Posted May 23, 2018 You may well have reached the limit of what AutoCAD 2007 will operate under in regards to an OS. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted May 23, 2018 Share Posted May 23, 2018 Hardware Acceleration is available in AutoCAD, try Options>Systems>3d Performance, it has nothing to do with any particular computer. What graphics card do you have? It may be as simple as finding the best driver. The easy fix is to use a program designed for Windows 10 or install Windows 7. Quote Link to comment Share on other sites More sharing options...
Levco101 Posted June 23, 2018 Author Share Posted June 23, 2018 I tried everything found here and on other web searches. Ended up installing the Longbow Converter. My AutoCad 2007 is working perfectly so far-10 days or so. Thank you all for your HELP!!! Stan Quote Link to comment Share on other sites More sharing options...
addysmith97 Posted September 3, 2018 Share Posted September 3, 2018 hey friend, I think this specification is not designed to run with win 10 Quote Link to comment Share on other sites More sharing options...
EL IDRISSI HAMID Posted January 25 Share Posted January 25 Tanks Quote Link to comment Share on other sites More sharing options...
