Quote Originally Posted by Cad64 View Post
Ok, you should have one linear parameter on your border with a stretch action applied. Then you need to add a second stretch action, for your hatch boundary, tied to that same linear parameter. Choose the stretch action and select your linear parameter and pick the same "parameter point to associate with action" that you chose for the first stretch action. Now, when you pick the "corners of stretch frame", pick the corners of your hatch boundary polyline and when asked to select objects, select your hatch boundary polyline.
I hope that all makes sense. If not post back and I will try explain it better.
I am also trying for the same, but the hatch is a diagonal pattern.
Help me if someone have an idea about.
I need to stretch the attached block both ways.
https://www.dropbox.com/s/5zfkz03zy7...block.dwg?dl=0
