Starkey
Hatch, Stretch, Dynamic Block...
Starkey
So I created a block of text with a simple border around it. I have a drop shadow on the border that is simply lines with a solid hatch. When I try to give the block the stretching action (as to fit varying lengths of text for room labels) it works fine, but doesn't want to stretch the hatching. The hatch will just move instead of get longer or shorter.
Hope this makes sense,
-Taylor
Share this post
Link to post
Guest Alan Cullen
If you make those lines surrounding the hatch a polyline boundary, then pick that boundary for your hatch.....then when you stretch your text box, the hatch should move to occupy the new position of your boundary.
P.S. We do the same thing with text we want to stand out... :)
Share this post
Link to post
Cad64
Ok, you should have one linear parameter on your border with a stretch action applied. Then you need to add a second stretch action, for your hatch boundary, tied to that same linear parameter. Choose the stretch action and select your linear parameter and pick the same "parameter point to associate with action" that you chose for the first stretch action. Now, when you pick the "corners of stretch frame", pick the corners of your hatch boundary polyline and when asked to select objects, select your hatch boundary polyline.
I hope that all makes sense. If not post back and I will try explain it better.
Share this post
Link to post
Starkey
I'm jumping on it right now...I will let you know in a sec if it works. I understand what you're getting at.
Share this post
Link to post
Starkey
Gorgeous...just had to create a polyline for the hatch border, then do two stretch actions under one linear parameter, one for the hatch PL and one for the main text box.
Thank you both!
Share this post
Link to post
Dommy2Hotty
Perhaps the hatch wasn't associative from the start? I'm just guessing here. If it was associative, I don't think you'd have to do 2 stretch actions.
Share this post
Link to post
Starkey
But it would still have to be a polyline border around the hatch wouldn't it? I didn't have a PL when I asked the question originally.
Share this post
Link to post
Cad64
Regardless of whether the hatch is associative or not, a second stretch action is required in order to get the hatch boundary to stretch with the text border. Without that second stretch action the hatch boundary just moves with the border. Obviously if the hatch is not associative it will not fill the boundary after stretching, but in order to get both the border and the hatch boundary to stretch together, you need two actions tied to the linear parameter.
Share this post
Link to post
Dommy2Hotty
Duely noted. I don't have much experience with Dynamic Blocks. I just tried my way and it did not work...
Share this post
Link to post
Dommy2Hotty
Actually, my way DID work, but after I stretched it once, the hatch looses it's associativity, so the second stretch action keeps the same hatch...
Share this post
Link to post
isutheparambil
I am also trying for the same, but the hatch is a diagonal pattern.
Help me if someone have an idea about.
I need to stretch the attached block both ways.
https://www.dropbox.com/s/5zfkz03zy7m7r7f/dyn.block.dwg?dl=0
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
