+ Reply to Thread
Results 1 to 3 of 3
  1. #1
    Full Member
    Computer Details
    dal-designs's Computer Details
    Operating System:
    Windows 7
    HP Compaq Elite 8300 SFF
    dal-designs's Discipline Details
    Designer in Oil and Gas Industry
    facilities planning (retail/wholesale fuels and chemicals) aerial surveying and GIS mapping; building design, facilities planning, land development
    AutoCAD 2015
    Join Date
    Feb 2014
    Victoria, Texas
    Question Custom Hatch Pattern Troubleshooting
    After spending waaaay too much time looking for a board and batten hatch pattern for vanilla ACAD, I found this in a Revit forum:
    *Board & Batten, 2.5" Batten at 16" o.c.
    90, 0, 0, 16, 16, 16
    90, 2.5, 0, 16, 16, 16
    Doesn't work for vanilla ACAD, though. Since I don't know the first thing about LISP programming (somehow it is never as 'easy' as the people who say, "Oh, it's easy!" claim), would anyone be kind enough to help me figure out what needs to change to be a regular ol' AutoCAD .pat?
    Sucking at something is the first step to being kinda good at it
  2. #2
    Quantum Mechanic
    Civil 3D 2016
    Join Date
    Dec 2005
    Have a look at acad.pat or acadiso.pat in particular say brick pattern or this
    *BRICK, Brick or masonry-type surface
    0, 0,0, 0,.25
    90, 0,0, 0,.5, .25,-.25
    90, .25,0, 0,.5, -.25,.25
    *AR-B88, 8x8 Block elevation stretcher bond
    0, 0,0, 0,8
    90, 0,0, 8,4,
  3. #3
    Senior Member
    not applicable
    Join Date
    Nov 2006
    Melbourne Australia
    Quote Originally Posted by dal-designs View Post
    Main problem is there's 6 numbers in each element definition when unbroken lines need only 5 viz:
    angle, x-origin, y-origin, shift, spacing where shift can be zero for unbroken lines.
    Pattern name must match pattern filename so simplify the name and store this in BOARDBATTEN.PAT somewhere on your support file search path:
    *BoardBatten, Battens at 16 in centres.
    90, 0, 0, 0, 16
    90, 2.5, 0, 0, 16
    should show pairs of vertical lines 2.5 units apart repeated at 16 units. If you are working in inches that should be what you want otherwise scale accordingly.
    Hugh Adamson
Similar Threads
  1. I want to create custom hatch pattern own my choice?
    By afrazawan in forum The CUI, Hatches, Linetypes, Scripts & Macros
    Last Post: 15th Jun 2014, 05:07 pm
  2. custom hatch pattern frustrations
    By Annika in forum The CUI, Hatches, Linetypes, Scripts & Macros
    Last Post: 1st Mar 2013, 02:07 pm
  3. Custom Hatch Pattern AutoCAD 2012
    By MRAKA in forum AutoCAD General
    Last Post: 1st Mar 2012, 09:24 am
  4. custom hatch pattern sorting?..
    By hazardman in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 6th Nov 2008, 02:42 pm
  5. How do I create a custom hatch pattern?
    By WilliamMothershead in forum AutoCAD General
    Last Post: 9th Jan 2007, 10:56 am
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
