araslan Posted April 9, 2008 Share Posted April 9, 2008 I have a strange thing that recently started on a file that I've been working for a while. All of a sudden I can't select line/poly lines to modify, howe3ver I can with others on the same layer. I've noticed the lines I have problems with are generally in the same direction. Some times I can highlight but can't tag to the snap markers. I did command and did a select – all and changed the elevation to '0' and it actually worked for a while, but it reappeared again. When I hit regen those lines disappear and reappear again when I open the file again or when I play with the attribute display. I'm just confused, ANY IDEAS. Thanks Quote Link to comment Share on other sites More sharing options...
rustysilo Posted April 9, 2008 Share Posted April 9, 2008 Maybe try running an audit and a purge on the dwg. If that doesn't work I'd give'r a restart to see if the problem remains. Quote Link to comment Share on other sites More sharing options...
araslan Posted April 9, 2008 Author Share Posted April 9, 2008 I purge and audit all the time and have restarted and still the same. Quote Link to comment Share on other sites More sharing options...
NBC Posted April 9, 2008 Share Posted April 9, 2008 can you post a portion of the drawing you are having trouble with please Quote Link to comment Share on other sites More sharing options...
araslan Posted April 9, 2008 Author Share Posted April 9, 2008 ok, as soon as i figure out how to post a file on the site. thanks Quote Link to comment Share on other sites More sharing options...
araslan Posted April 9, 2008 Author Share Posted April 9, 2008 I'm having problems uploading the file for some reason! it fails everytime Quote Link to comment Share on other sites More sharing options...
cadfly Posted April 9, 2008 Share Posted April 9, 2008 araslan, I've had this happen recently also. Although i can't figure out what caused it, i can remedy it in the drawing. try this: 1. select "CTRL"+"A" to select all. 2. delete all of the entities 3. very important step, select "OOPS", do not leave this step out. Now you should be able to select the entities that were previously un-selectable. If anyone has a fix to this, please let me know. thanks Quote Link to comment Share on other sites More sharing options...
Cad64 Posted April 9, 2008 Share Posted April 9, 2008 I'm having problems uploading the file for some reason! it fails everytime See here: "How to add images to your posts" Make sure your Cad file is under 250kb. Quote Link to comment Share on other sites More sharing options...
AVITWeb Posted April 10, 2008 Share Posted April 10, 2008 It's worth a shot here, but I do not think it will actually work... Is your 0 (zero) layer frozen or turned off? Same goes for defpoints Quote Link to comment Share on other sites More sharing options...
sadhu Posted December 2, 2010 Share Posted December 2, 2010 I've had this happen recently also. Although i can't figure out what caused it, i can remedy it in the drawing. try this: 1. select "CTRL"+"A" to select all. 2. delete all of the entities 3. very important step, select "OOPS", do not leave this step out. Thanks cadfly, This one worked for me - I had a similar problem. Quote Link to comment Share on other sites More sharing options...
mokstar Posted December 3, 2010 Share Posted December 3, 2010 (edited) Same problem happening to me!!! Edited December 3, 2010 by Cad64 Removed profanity Quote Link to comment Share on other sites More sharing options...
Cad64 Posted December 3, 2010 Share Posted December 3, 2010 Please mind your language. Quote Link to comment Share on other sites More sharing options...
J3an Posted August 2, 2012 Share Posted August 2, 2012 The same thing is happening with me, it is really weird! any solutions found? I open to edit a block in block editor, but then i can't select some of the lines. I tried auditing and purging the file but nothing worked. Finally i tried orbiting the block in block editor and for some reason i could select the lines again! Any idea why this is happening? Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 2, 2012 Share Posted August 2, 2012 Without having a copy of the block to play with it's impossible to say exactly what is happening and why. Quote Link to comment Share on other sites More sharing options...
n0tepad Posted March 30, 2013 Share Posted March 30, 2013 It's worth a shot here, but I do not think it will actually work... Is your 0 (zero) layer frozen or turned off? Same goes for defpoints thanks avitweb! Quote Link to comment Share on other sites More sharing options...
qhabz Posted January 28, 2015 Share Posted January 28, 2015 "reconcile" layers will solve the problem Quote Link to comment Share on other sites More sharing options...
n0_name Posted February 3, 2017 Share Posted February 3, 2017 i had the same problem with a few polylines ( i couldn't select them one by one with the mouse, but using quick select i managed to select them) . Audit,delete and then oops didn't work. My polylines were on defpoints, and a few (other) layers were turened off. I turned all the layers in my drawing on and then i could select them again. Don't know what the problem was, but it works now.... Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 3, 2017 Share Posted February 3, 2017 The problem was twofold. 1) Your polylines were on the defpoints layer (not a good practice) and 2) layer "0" was probably frozen. Quote Link to comment Share on other sites More sharing options...
Net_guy Posted October 22, 2017 Share Posted October 22, 2017 Try to change the Model or Paper Space. Command Line: MSPACE (or PSPACE) See if it works Quote Link to comment Share on other sites More sharing options...
aarzoo khan Posted July 11, 2018 Share Posted July 11, 2018 i am having the same problem. But will u pls tell me where does this "oops" option come? Quote Link to comment Share on other sites More sharing options...
