Results 1 to 3 of 3
    Forum Newbie
    MEP 2009
    Aug 2008
    2
    Default Can't select objects
    Hi everyone, first timer and Newbie here. Just starting out in the ACAD world... been a Visio guy for a while.
    Just received a DWG file with a floorplan that contains Fire Alarm devices on it. It opens fine in AC but, I *can't* seem to pick any object. Hovering over or directly selecting any object, makes No change?
    I've got the current layer selected, unfrozen, unlocked, open - thru layer manager, but just can't select anything. I can change the color of all objects within the layer but can not select a specific object or group of objects.
    It's almost as if the file is protected from any changes. Tried various changes, even added/moved/resized my own objects without any problem, but the original objects just remain untouchable???
    So, what simple thing am I missing here???
    Thanks in advance, John
    Luminous Being dbroada's Avatar
    dbroada's Computer Details
    XP Pro
    Dell
    Intel Xeon 2.13GHz
    2GB
    NVIDA Quadro FX 580
    DELL 23" & SAMSUNG 21"
    Electro/Mech
    dbroada's Discipline Details
    Design Engineer
    Electro/Mech
    Electrical 2013
    Nov 2005
    Sussex, UK
    5,032
    you could be in paper space. do you have a tab at the bottom of the screen with MODEL on it. If so press there and try again.
    "That's it. It's one thing for a ghost to terrorize my children, but quite another for him to play my Theremin." Homer Simpson
    Dave
    Forum Newbie
    MEP 2009
    Aug 2008
    2
    Default Over the fence
    Dave;
    You nailed that one over the fence. Yes, it appears that I was in fact in the wrong layout space. In my case, I have buttons along the bottom/middle which allowed me to change space and make the edits.
    Thanks for your quick reply.
    John
  1. I have to shift-select to select multiple objects
    By PDS in forum AutoCAD Beginners' Area
    Last Post: 29th Nov 2011, 08:15 pm
  2. Using Filter to select objects
    By Dan5 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 30th Apr 2008, 02:25 pm
  3. Quickly select objects with Quick Select
    By AutoCAD Tips Blog in forum AutoCAD RSS Feeds
    Last Post: 23rd Dec 2007, 01:13 am
  4. how to select objects
    By luisjeronimo in forum AutoCAD Beginners' Area
    Last Post: 14th Jul 2007, 05:27 pm
  5. Cannot select objects.
    By danpooler in forum AutoCAD Drawing Management & Output
    Last Post: 2nd May 2007, 09:45 pm
