Named UCS and PLAN all in one LISP not working
Hi all,
Am working on a bit of code to help out my workload,
alot of times i'm working at wierd angles on BIG plans, so
i do named ucs's to make life easier.
Here's the problem, I've written the code posted below, but it doesn't
seem to work - can someone tell me where i've gon wrong?
;**                  THIS ROUTINE IS FOR RESTORING                **
;**                  A NAMED UCS AND RUNNING THE                  **
;**                  PLAN COMMAND AT THE SAME TIME                **
;**                  (C) PETER SMITH 03-02-2009                   **
;**                  PROVIDED FOR USE BY ALL PLEASE               **
;**                  INCLUDE THIS HEADER WHEN COPYING             **
;** CONTACT TO REPORT PROBLEMS: skipsophrenic@hotmail.com         **
defun c:ucsplan () ;defined function
           (command "ucs" "na" "re") ;runs the ucs restore option
                       (getstring "\nName of ucs:") ;asks for the name of the ucs wanted
           (command "Plan" "C") runs the plan command and set's it to current ucs
  • Replies 51
  • Lee Mac
    21
  • skipsophrenic
    17
  • uddfl
    4
  • GE13579
    3
Maybe this:
(command "ucs" "na" "re" pause)
so you don't need the 'getstring' which I think is the problem having is separate.
Not sure why the "na", but maybe:
(defun c:ucsplan (/ uNm)
 (if (and (setq uNm (getstring t "\nSpecify Name of UCS: "))
      (tblsearch "UCS" uNm))
     (command "_ucs" "Re" uNm)
     (command "_plan" "c"))
   (princ "\nUCS Name not Found. "))
 (princ))
Carl, is the UCS prompts different for ACAD '08?
Why is the "na" required?
To state i want to input a named ucs that I had saved previously - just off to test the code now
Hmmm... on '04, I just type "UCS" "RE" and then type the name of the UCS.... and it restores it ... :unsure:
Tested and keep getting the following:
Command: _appload ucsplan.lsp successfully loaded.
Command: ucsplan
Unknown command "UCSPLAN". Press F1 for help.
Lee,
Yes prompts are different in 2008:
Command: ucs
Current ucs name: xxx
Specify origin of UCS or [Face/NAmed/OBject/Previous/View/World/X/Y/Z/ZAxis]
: na
Enter an option [Restore/Save/Delete/?]: r
Enter name of UCS to restore or [?]:
:D Your header has more lines than your routine. Sorry, I had to say it.
Lee,
Command: ucs
: na
Thanks Carl:
     (command "_ucs" "NA" "R" uNm)
(princ))
Command: ucsplan
Are you testing yours or mine?
Because obviously yours is missing quite a few brackets...
I'm not good at lisp, but I did notice you're missing a semicolon before "runs the plan command..."
Nice spot Seneb,
Also, you are missing an open bracket for the defun, you have (princ) outside of the function, and you haven't set your string retrieval to any variable.
Just a few pointers. :thumbsup:
Thanks, Lee Mac. I do some web coding, so stuff like that jumps out at me. :)
Was testing yours lee.
I'll go back and edit mine with updates mentioned here and see how that goes
:lol: I noticed the same myself, but that's my standard header now. LOL
LEE,
Sorry when i copied your corrections I missed the last closing
parenthesis, rechecked and job done.
Thanks :thumbsup:
No worries Peter - glad you got it working :)
Good luck with your coding :thumbsup:
Cheers
Lee
Thanks, I will need the luck - am tryin to figure out how to ask operator to choose which layout to go to, and then have it draw a viewport scaled to fit, with the selected ucs as the plan - fun no? all as part of same routine
:reallymad: :reallymad: :reallymad: help pls, i've gone through ev'ry website I know and
turned up nothing - except colourful definitions of the word LISP - all
I'm after is the choos layout bit, as mentioned before - only reason I
haven't asked before is I'm a great beleiver in try and figre it out for
yourself first, then it sticks in your head longer
Hence why i angry with myself!
