Named UCS and PLAN all in one LISP not working
I'll give it a try in a bit - got not much time to at moment - bit of a rush job on - AAARRGH! LOL :lol:
  • Replies 51
  • Lee Mac
    21
  • skipsophrenic
    17
  • uddfl
    4
  • GE13579
    3
Hahah, let me know the results once the rush job has finished! :)
Don't let the boss catch you on here! He'll only think its an angling site :)
thanks for the help Lee, that's done the trick :)
I'm off to start a new lisp now (not too complicated i hope)
Want me to include you in the title header?
Excellent! Glad it works like you want it to :)
As for the title header.... only include me if I have helped you with it... credit where credit's due and all :)
Shall we see if the code can have more lines than the header this time :thumbsup: :)
for the next 0ne I hope so! LOL
For the one pertaining to this thread - headder for your approval?
Any changes/suggestions?
;** THIS ROUTINE IS FOR RESTORING
;** A SAVED UCS AND RUNNING THE
;** PLAN COMMAND AT THE SAME TIME
;** ALSO GOES TO A USER CHOSEN LAYOUT
;** AND STARTS VIEWPORT COMMAND
;** COPYRIGHT (C) PETER SMITH & LEE MAC
;** ORIGINAL CONCEPT/PROGRAMMING BY PETER SMITH
;** PROGRAMMING/DE-BUGGING BY LEE MAC
;** PROVIDED FOR USE BY ALL PLEASE
;** INCLUDE THIS HEADER WHEN COPYING
;** CONTACT TO REPORT PROBLEMS: [email="skipsophrenic@hotmail.com"]skipsophrenic@hotmail.com[/email]
  • 8 months later...
I'm looking at something along these lines, but am wondering if it can be added to a toolbar button? What I'm aiming for is a button which prompts the commands UCS- RE, asks for a name, then continues with PLAN- CURRENT UCS. Is this possible to create in a button, or does it need to be in a LISP form?
Also just to clarify a couple of points earlier in this thread;
NA is a step which can be bypassed in 2009- not sure about 2008, but you can use either command sequence,
Command: ucs
Current ucs name: SF04
Specify origin of UCS or [Face/NAmed/OBject/Previous/View/World/X/Y/Z/ZAxis]
: na
Enter an option [Restore/Save/Delete/?]: re
Enter name of UCS to restore or [?]:
Command: ucs
: re
You can even drop the 'e' from 're':
Command: ucs
: r
Also, VPORTS is a command for MS viewports, ie it will break up the model space into x number of view ports, it's different to the MVIEW command.
Thanks in advance for any help with this. I must admit LISP and macros aren't my strongest point so please bear with me...
And thanks to all who have contributed to this thread as I might well be utilising Skips'/ LeeMacs LISP routine if the macro option isn't possible...
It's possible to make it into a button (not sure why you would go that route when LISP is so much better), but it's possible. Just use a ";" to signify when a call is finished and a \ when you want to pause for user input.
^C^CUCS;re\
Hi Alan,
Thank you for your reply. I've never used macros before to create a button, but just to clarify, (I'm also wondering why you didn't include the ';' between the '^C^C' and the UCS command- is this standard?) would the macro say for UCS, W, PLAN, CURRENT UCS look like-
^C^CUCS;W;PLAN;C
Could I also assign buttons for specific UCS' such as-
^C^CUCS;R;;PLAN;C
Then a general one with which I could name a UCS from-
^C^CUCS;R\PLAN;C
Can you confirm the above?
Cheers Alan!
Just an update- the above works well thank you Alan! Sorry I've been calling you by the wrong name! Well... it's Monday... :oops:
Sorry about that!
The only notes are that I missed off the ';' at the end of each and I couldn't get the last one to work but happened upon the UCSMAN command which kind of covers that, just i need an additional button :)
Sorry about that!
No sweat. :)
I'm glad you got it worked out. I'm not much of a macro writer since I know how to write LISP, but I know enough to point someone in the right direction.
