Francisodur Posted March 6, 2009 Share Posted March 6, 2009 I have aproblem using Autocad 2004. ihave failed to save a drawing. every time i try, it brings adailog box with an error 'Error writing/closing file'. how do i solve this problem? i need help! Quote Link to comment Share on other sites More sharing options...
Tiger Posted March 6, 2009 Share Posted March 6, 2009 Francisodur - I moved your post to it's new thread - please don't tack your new question onto an old thread. I recommend Copy-paste everything from your drawing into a new one and try to save and close - it usually works. Quote Link to comment Share on other sites More sharing options...
NBC Posted March 6, 2009 Share Posted March 6, 2009 This could also be a Read/Write access issue if trying to save the file onto a network folder. Quote Link to comment Share on other sites More sharing options...
skipsophrenic Posted March 6, 2009 Share Posted March 6, 2009 if you are trying to save to a network, you could save a copy on your computers harddrive first, and then copy that file over to the folder it needs to be in on the network. Quote Link to comment Share on other sites More sharing options...
Buddym Posted March 6, 2009 Share Posted March 6, 2009 A dwg that won't close properly can often be saved by wblocking the entire drawing, and picking any point except '0,0' for the inswertion point. Wblocking purges the drawing completely, even things that the Purge command cannot. Quote Link to comment Share on other sites More sharing options...
