Francisodur Posted March 6, 2009 Posted March 6, 2009 I have aproblem using Autocad 2004. ihave failed to save a drawing. every time i try, it brings adailog box with an error 'Error writing/closing file'. how do i solve this problem? i need help! Quote
Tiger Posted March 6, 2009 Posted March 6, 2009 Francisodur - I moved your post to it's new thread - please don't tack your new question onto an old thread. I recommend Copy-paste everything from your drawing into a new one and try to save and close - it usually works. Quote
NBC Posted March 6, 2009 Posted March 6, 2009 This could also be a Read/Write access issue if trying to save the file onto a network folder. Quote
skipsophrenic Posted March 6, 2009 Posted March 6, 2009 if you are trying to save to a network, you could save a copy on your computers harddrive first, and then copy that file over to the folder it needs to be in on the network. Quote
Buddym Posted March 6, 2009 Posted March 6, 2009 A dwg that won't close properly can often be saved by wblocking the entire drawing, and picking any point except '0,0' for the inswertion point. Wblocking purges the drawing completely, even things that the Purge command cannot. Quote
