Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 26
    Super Member MarcoW's Avatar
    MarcoW's Computer Details
    Microsoft Windows 7 Pro 64-bit
    A black one
    Intel Xeon E5520 Quad Core
    8 GB
    NVIDIA Quadro FX 580 - 512MB
    300 GB 10000 RPM
    AutoCAD 2011
    Apr 2009
    The Netherlands
    599
    Default Check / create layer issue in Lisp
    I wanted to make a routine that:
    1. checks if a linetype is loaded, if not then it should load it, if yes, then okay
    2. checks if a layer exists, if not create it (with a specific colour and linetype), if yes, set it current.
    This is my code:
    Code:
    (defun c:test ( / ltname layname laycol cmdold) ; functie definitie
    (setq ltname "center"  ; defines linetypename
     layname "test"   ; defines layername
     laycol 8   ; defines layer color
     cmdold (getvar "cmdecho")
    )     ; end setq
    (setvar "cmdecho" 0   ; no following by F2
    )     ; end setvar
    (if (= (tblsearch "ltype" ltname) nil)
    (command "linetype" "l" ltname "acad.lin" "")
    (if (= (tblsearch "layer" layname))
    (command "layer" "s" layname "")
    (command "layer" "m" layname "l" ltname "" "c" laycol "" "")
    (setvar "cmdecho" cmdold); cmdecho back to what it was
    (princ); Exit cleanly
    ); end of defun
    The problem is when the layer exists, it doesn't set it to current...
    I'm only 1 inch away from the solution I believe.... but I can't manage to do it.
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,732
    I have provided a VL option if you wanted to go down that route also:
    Code:
    (defun c:test (/ ltname layname laycol cmdold lay)
      (vl-load-com)
            layname "test"
            laycol 8
            cmdold (getvar "CMDECHO"))
      (setvar "CMDECHO" 0)
      ;; Loading Linetype  ~ Another option to consider:
      (if (not (tblsearch "LTYPE" ltname))
        (vla-load
          (vla-get-Linetypes
            (vla-get-ActiveDocument
              (vlax-get-acad-object))) ltname "acad.lin"))
      ;; Layer Checking & Creation
      (if (not (tblsearch "LAYER" layname))
        (command "_.-layer" "_M" layname "_L" ltname layname "_C" laycol layname "")
        (setvar "CLAYER" layname))
      ;; Another Option for Layer Creation to Consider:
          (setq lay (vla-add
                      (vla-get-layers
                          (vlax-get-acad-object))) layname))
          (vla-put-color lay laycol)
          (vla-put-linetype lay ltname)))
      ;; Reset CMDECHO
      (setvar "CMDECHO" cmdold)
      (princ))
    Lee Mac Programming
    Just another Swamper
    A black one
    8 GB
    300 GB 10000 RPM
    AutoCAD 2011
    Apr 2009
    The Netherlands
    599
    Lee,
    It works properly allthough i don't get the code. It's too much to get in to that, so let's leave that part for what it is.
    This example (test.lsp) is for 1 layer, 1 linetype an 1 colour.
    I wonder if it can be made for multiple layers. Not in the way I do it now, thats wrong, defnitly!
    I copy the code 10 times and change c:test into c:test1 c:test2 etc. Then per function I modifiy the names.
    I wouldn't know how to do it else for test1 calls a specific layer.
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,732
    The code is not that complicated to explain - I could try to answer any questions you may have about it.
    As for multiple layers, colours etc - Make the layer function into a sub-function, and call it with multiple arguments:
    Code:
    (defun mklay (layname laycol ltname / lay)
      (vl-load-com)
        (vla-load
          (vla-get-Linetypes
          (setq lay (vla-add
                      (vla-get-layers
    (defun c:test ()
      (mapcar 'mklay
              '("test1" "test2" "test3")
              '(8 3 4)
              '("CENTER" "HIDDEN" "CONTINUOUS"))
      (princ))
    This will make three layers:
    test1 -- colour 8 -- CENTER
    test2 -- colour 3 -- HIDDEN
    test3 -- colour 4 -- CONTINUOUS
    Hope this helps,
    Lee
    Lee Mac Programming
  5. #5
    Senior Member TimSpangler's Avatar
    Architecture 2009
    Jan 2008
    Gettyburg, PA
    212
    Idea
    Here is a Linetype loading sub that I use all the time, along with a helper sub.
    Just pass it a linetype name and it will search every .lin files in your search path and if it finds it, it gets loaded.
    The only thing that I want to do to it, is if a path is supplied than it loads the linetype directly.
    Timothy Spangler
    --theswamp--
  6. #6
    Full Member
    AutoCAD 2004
    Feb 2009
    65
    Heres one that I use it purges all unused layers then create the 10 layers I use. You can modify the layer names to your liking and at the end of the dolayers command you can modify to set layer current.
    (setvar "clayer" "insert layer name here")
    I know its rokkie programing but it works for me. I use it to make sure all our drawing have the same layers since I'm the 4th draftsman here we have a lot of different drawings.
    Oh and thanks Lee Mac I saw something like this in one of his commands so I just made some mod's to it.
    Code:
    (defun createlayer (NAME)
     (if
      (not (tblsearch "LAYER" NAME))
      (command "-layer" "m" "CEN" "C" "6" "CEN" "L" "CENTER" "CEN" "LW" "0.18" "CEN" "")
     (if
      (command "-layer" "m" "DIMS" "C" "1" "DIMS" "LW" "0.18" "DIMS" "")
     (if
      (command "-layer" "m" "HAT" "C" "3" "HAT" "LW" "0.18" "HAT" "")
     (if
      (command "-layer" "m" "HID" "C" "4" "HID" "L" "HIDDEN" "HID" "LW" "0.15" "HID" "")
     (if
      (command "-layer" "m" "LOGO" "C" "176" "LOGO" "LW" "0.09" "" "")
     (if
      (command "-layer" "m" "OBJ" "C" "2" "OBJ" "LW" "0.40" "OBJ" "")
     (if
      (command "-layer" "m" "PAPER" "C" "5" "PAPER" "L" "PHANTOM" "PAPER" "P" "N" "PAPER" "")
     (if
      (command "-layer" "m" "PHAN" "C" "6" "PHAN" "L" "PHANTOM" "PHAN" "LW" "0.18" "PHAN" "")
     (if
      (command "-layer" "m" "TITLE" "C" "176" "TITLE" "")
     (if
      (command "-layer" "m" "TXT" "C" "7" "" "")
    (defun c:dolayers ()
     (setvar "cmdecho" 0)
     (purgelayers)
     (mapcar 'createlayer '("CEN" "DIMS" "HAT" "HID" "LOGO" "OBJ" "PAPER" "PHAN" "TITLE" "TXT"))
  7. #7
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,732
    Quote Originally Posted by bradb View Post
    Code:
     (if
     (if
     (if
     (if
     (if
     (if
     (if
     (if
     (if
     (if
     (purgelayers)
    Bradb,
    the way you have called the sub-function, each statement is independent of the argument supplied. I.e. Every IF statement will return T for every single layer that doesnt exist.
    Lee Mac Programming
  8. #8
    Full Member
    AutoCAD 2004
    Feb 2009
    65
    Quote Originally Posted by Lee Mac View Post
    Bradb,
    Ah is that because I purged all layers away prior to create layer. I originally wanted it to search for layers then rename them. Ex. search for OBJECT and OBJ. And OBJECT rename to OBJ. And if OBJ then nothing will happen, But if neither exist then create OBJ.
  9. #9
    Forum Deity
    AutoCAD 2009
    Oct 2008
    2,112
    You should do just one tablesearch with an argument and use conditionals to make the layers.
  10. #10
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,732
    No, it is because you are supplying every IF statement with the same argument.
    This is much better (and much faster):
    Code:
    (defun MkLay (Nme Col lTyp lWgt Plt / lay)
      (vl-load-com)
      (setq lay
        (vla-add
          (vla-get-layers
              (vlax-get-acad-object))) Nme))
      (and Col (vla-put-Color lay Col))
      (and lTyp (vla-put-Linetype lay lTyp))
      (and lWgt (vla-put-LineWeight lay lWgt))
      (and (not Plt) (vla-put-Plottable lay :vlax-false)))
    (defun c:DoLayers ()
      (purgelayers)
      (mapcar 'MkLay
              '( "CEN"   "DIMS" "HAT"  "HID"   "LOGO" "OBJ"  "PAPER"   "PHAN"   "TITLE" "TXT")  ; Name
              '(   6       1      3      4       176    2       5         6       176     7  )  ; Colours
              '("CENTER"  nil    nil  "HIDDEN"   nil   nil  "PHANTOM" "PHANTOM"   nil    nil )  ; LineType
              '(  0.18   0.18   0.18    0.15    0.09  0.40     nil      0.18      nil    nil )  ; LineWeight
              '(   T       T      T      T        T     T      nil        T        T      T  )) ; Plottable (T or nil)
      (princ))
    I'm not sure what your "purgelayers" function does, but maybe I could improve that also
    Lee Mac Programming
  1. lisp file to create command to chprop to a specified layer
    By NoelStalker in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd Oct 2008, 09:26 pm
  2. Check for locked layer..
    By hardwired in forum AutoLISP, Visual LISP & DCL
    Last Post: 14th Aug 2008, 12:58 pm
  3. Lisp routine help, Layer check problem
    By craig.baldie in forum AutoLISP, Visual LISP & DCL
    Last Post: 12th Oct 2007, 07:29 am
  4. Brickwork Dimension Lisp/check?
    By James in forum AutoCAD General
    Last Post: 24th Jun 2007, 07:57 pm
  5. Find and/or Create a Layer using LISP
    By FindAPath in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Jul 2006, 10:04 pm
