hi everyone!
I have coordinates in MS excel and I want to plot it in autocad 2008, is there any autolisp on this so that I cant spend a lot of time typing coordinates one by one in autocad?
can anyone help me on this?
___________________________
sorry for my english
  • Replies 30
  • fbby
    7
  • Lee Mac
    7
  • wannabe
    6
  • ReMark
    4
Posted Images
You want to insert block's at those coordinates?
hi everyone!
this one works perfectly..but 1st convert excel to txt format.
http://www.cadtutor.net/forum/showthread.php?t=36808
:wink:
Here's an application I created myself if you want to Insert blocks. User-guide attached, although the only real issue is formatting your excel spreadsheet.
Like standard AutoCAD pallettes, you can drag this around your screen and doesn't need to be docked at the edge of your screen.
MBP.zip
Was this any good for your needs??
I see no mention of the OP inserting blocks at these coordinates.
There is no need to use AutoLISP. Click on the link at the top of this page to Michael's Corner. Look at the May 2009 column. Page down until you get to the heading named The Odd Spot. In this month's entry, aptly named Coordinates from Excel to AutoCAD, Michael Beall explains how to get coordinates from Excel into AutoCAD using a script (scr) file.
hi everyone!
* Open your Excel file.
* Save it as a CSV file.
* Close Excel.
* Find the CSV file, open it in Notepad.
* At the TOP of the file, add two lines:
MULTIPLE
POINT
* Save the file as a .SCR file.
* Run this script file in AutoCAD.
* Close Excel.
MULTIPLE
POINT
Great tip.
The application I've attached will insert user-selected blocks and also populate the attributes field if it's of use to anyone.
There's no mention of what he does want, to be fair.
sorry guys if I late reply
I want to connect the coordinates by polylines, like if I type the coordinates in excel it will automatically connect by the polylines
I think ReMark's referal wins:D
If not, this should work (assumes 2D):
(defun c:ptpoly (/ doc spc file nl ptlst)
 (vl-load-com)
 (setq doc (vla-get-ActiveDocument
             (vlax-get-Acad-Object))
       spc (if (zerop (vla-get-activespace doc))
             (if (= (vla-get-mspace doc) :vlax-true)
               (vla-get-modelspace doc)
               (vla-get-paperspace doc))
             (vla-get-modelspace doc)))
 (if (setq file (getfiled "Select File" "" "txt" )
     (setq file (open file "r"))
     (while (setq nl (read-line file))
       (setq ptlst (cons (StrBrk nl 44) ptlst)))
     (close file)
     (if ptlst
         (setq ptlst
                (apply 'append
                       (mapcar
                         (function
                           (lambda (x)
                             (list (car x) (cadr x))))
                         (reverse
                           (mapcar
                             (function
                               (lambda (x)
                                 (mapcar 'distof x))) ptlst)))))
         (vla-addLightweightpolyline spc
           (vlax-make-variant
             (vlax-safearray-fill
               (vlax-make-safearray
                 vlax-vbdouble
                 (cons 0 (1- (length ptlst)))) ptlst))))
       (princ "\n<< No Points Found in File >>")))
   (princ "\n<< No File Selected >>"))
 (princ))
(defun StrBrk (str chrc / pos lst)
 (while (setq pos (vl-string-position chrc str))
   (setq lst (cons (substr str 1 pos) lst)
         str (substr str (+ pos 2))))
 (reverse (cons str lst)))
In that case I'll take a beer as my prize. Thank you very much.
I attached my some coordinates
Please check it
If you do not want to go with ReMarks method - could you copy your coordinates into a Text file and tell me what separates them, whether it be a TAB, SPACE or COMMA.
It's space
X Y
135643 4740
135650 4737
135656 4734
Ok, if you remove the X Y from the top of the text file, this should work:
 (vl-load-com)
       (setq ptlst (cons (StrBrk nl 32) ptlst)))
     (close file)
     (if ptlst
         (setq ptlst
                (apply 'append
                       (mapcar
                         (function
                           (lambda (x)
                         (reverse
                           (mapcar
                             (function
                               (lambda (x)
           (vlax-make-variant
                 vlax-vbdouble
 (princ))
 (vl-load-com)
     (close file)
     (if ptlst
         (setq ptlst
                (apply 'append
                       (mapcar
                         (function
                           (lambda (x)
                         (reverse
                           (mapcar
                             (function
                               (lambda (x)
           (vlax-make-variant
                 vlax-vbdouble
 (princ))
can you please tell what I will do?
____________________________
