criehle Posted July 13, 2009 Share Posted July 13, 2009 Does anyone know if there is a way to remove a block defintion from a drawing? or make the block text not attatched to the block defintion? Quote Link to comment Share on other sites More sharing options...
fuccaro Posted July 13, 2009 Share Posted July 13, 2009 try the PURGE command Quote Link to comment Share on other sites More sharing options...
criehle Posted July 13, 2009 Author Share Posted July 13, 2009 I tried purge but it won't work because there are blocks in my current drawing that reference the block defintion I want to delete. Quote Link to comment Share on other sites More sharing options...
JoeC Posted July 13, 2009 Share Posted July 13, 2009 Have you tried BEDIT to remove the nested block or block text you don't want? Quote Link to comment Share on other sites More sharing options...
criehle Posted July 13, 2009 Author Share Posted July 13, 2009 I tried that as well and I didn't get the results I wanted. I think I figured it out though. I used QSELECT to select all of the blocks and then deleted the block text in the properties that I didn't want to show on the drawing. I then used the BURST command to remove the block reference. This created the block reference as text and removed those blocks from referencing the block defintion that I wanted to delete. Thanks for your suggestions. Quote Link to comment Share on other sites More sharing options...
