criehle
Block Definition
criehle
Does anyone know if there is a way to remove a block defintion from a drawing? or make the block text not attatched to the block defintion?
Share this post
Link to post
fuccaro
try the PURGE command
Share this post
Link to post
criehle
I tried purge but it won't work because there are blocks in my current drawing that reference the block defintion I want to delete.
Share this post
Link to post
JoeC
Have you tried BEDIT to remove the nested block or block text you don't want?
Share this post
Link to post
criehle
I tried that as well and I didn't get the results I wanted. I think I figured it out though. I used QSELECT to select all of the blocks and then deleted the block text in the properties that I didn't want to show on the drawing. I then used the BURST command to remove the block reference. This created the block reference as text and removed those blocks from referencing the block defintion that I wanted to delete. Thanks for your suggestions.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
