Hi
Could you correct my code?!?
1- I need to open a file.
2-Check if the first number is the same of my variable.
3- yes, do.....
4 no, check the next line
I search in this forum, I found a few thread about "freefile"
http://www.cadtutor.net/forum/showthread.php?t=27744
But I didn't found the way to solve my problem.
The variable strTexte still empty and the sub dont stop, it's "loop":huh:
(I temporarily remove the "if" section)
Sub FindScale(strVpScaleStd As String, strVpScaleCust As String)
   Dim strNomFichier As String
   Dim NomCalque As String
   Dim strTexte As String
   Dim iFichier As Integer
   Dim Position As Integer
   Dim strEchelle As String
   On Error Resume Next
   strNomFichier = "c:\vba\test.txt"
   iFichier = FreeFile
   Open strNomFichier For Input As #iFichier
   If Err Then
       MsgBox "Fichier " & strNomFichier & " introuvable."
       Exit Sub
   End If
   iFichier = FreeFile
   Do While Not EOF(iFichier)
       Line Input #iFichier, strTexte
           strTexte = Left(strTexte, 3)
           'If Left(strTexte, 3) = strVpScaleStd Then
           '    Position = InStr(strTexte, "*")
           '    strEchelle = Mid$(strTexte, Position + 1)
           'Else
           '    strTexte = ""
           'End If
   Loop
   Close #iFichier
   If strEchelle = "" Then
   MsgBox "actual scale = " & strVpScaleCust
   End If
End Sub
Thanks
Reference ms scription runtime
dim fso as new filesystemobject
dim fil as textstream
set fil = fso.opentextstream
while fil.eof == false
wend
EDIT:
the actual method you are looking for is fil.OpenTextFile()
that is only psuedo code but it should be enough to get you going
