Creating undeletable object - possible?
the-trooper
Hello everyone.
Is it possible to create an undeletable object (line or text) in a dwg? I need something that would serve as "trademark" on DEFPOINTS, in our blocks sent to others.
Thanks in advance!
  • Replies 61
  • Lee Mac
    22
  • the-trooper
    16
  • alanjt
    11
  • ReMark
    5
Posted Images
This sounds like something that might possibly be doable using Visual LISP but I'm not a programmer so I cannot say with 100% certainty that it can be done. I've read where someone has used Visual LISP to make objects visible or invisible by resetting their visibility property. Perhaps there is a 'lock' property? Someone like Lee Mac might be able to provide you with a more definitive answer.
How about switching off the Visibility of an Object?
AFAIK this makes it undetectable :)
visibility is the only real option.
however, the little light bulb at the bottom corner will show that something's visibility is 'turned off' and can easily be turned back on.
especially problematic if these functions are actually utilized by the user.
with the way C3D styles ignore layers, i use the isolate and hide function at times.
just a little food for thought.
.......can an object reactor prevent erasing?
Obviously, if you made a Block Invisible - it would still show up in the Block Editor, so an object would be better.
The Object would still appear in the drawing database, but would be "un-selectable" by the user (and would only be able to be accessed by other means).
Light bulb? :huh:
i take it back, it doesn't detect it.
(vla-put-visible (vlax-ename->vla-object (car (entsel))) :vlax-false)
will do exactly what you want.
What would you like to be made invisible?
One line of text, doesn't even need to be text, i can "write" it with lines/polylines.
But it must be visible, on screen. On defpoints, so others can plot normally.
Should be undeletable.
I thought we were trying to lock an object?
CADTutor himself suggested the use of a 'read-only' xref to a similar question. That assumes the person that the drawing is sent to does not know how to reset the read-only attribute. Do most people know how to do that these days? I do but then I grew up with DOS.
If it was invisibility you were looking for:
(defun c:invis (/ ent)
 (vl-load-com)
 (if (setq ent (car (entsel "\nSelect Object: ")))
   (vla-put-Visible
     (vlax-ename->vla-object ent) :vlax-false))
 (princ))
(defun c:vis (/ ss)
 (vl-load-com)
 (if (setq ss (ssget "_X"))
   (mapcar
     (function
       (lambda (x)
         (vla-put-visible
           (vlax-ename->vla-object x) :vlax-true)))
     (mapcar 'cadr (ssnamex ss))))
 (princ))
*couldn't resist*
But as for undeletable.... hmm, thats a bit trickier.
Obviously a locked layer is the simple answer, but that assumes they don't know how to unlock a layer.. which is pretty obvious.
Perhaps a persistent object reactor could do the trick, but I've never done anything like that, so we are stabbing in the dark a bit here...
