benw Posted November 24, 2009 Share Posted November 24, 2009 Hi GuysCan anybody tell me if they are using Windows 7 with Autocad 2009 and if they know of any problems. We will be upgrading to 7 and our office is using Acad 2009. Cheers Dodge I'm unsure about 2009, I have just installed Win7 64bit and am using Architecture 2010 with out any problems at all (only been a week) So far very happy with win7 Quote Link to comment Share on other sites More sharing options...
jnywu Posted December 1, 2009 Share Posted December 1, 2009 I have upgraded to Win7 x64, but have no problems whatsoever with autocad. Then again, I have switched over to autocad 2010, so i expect it to work well...I'll install 2006 just out of curiosity when I get home. Quote Link to comment Share on other sites More sharing options...
TeeSqr Posted December 5, 2009 Share Posted December 5, 2009 Upgraded to a new laptop with Win 7 32b, previous was XP Pro running Acad 2006 like a dream. However, when installed Acad 2006 on Win 7 machine it installed fine but came up with incompatible messages on start up but would open only when right clicking on acad icon and running as adminstrator! However, tried to install Arch 2010 but would roll back install near end with error message "....failed to load FNP_ACT.Installer....", downloaded the 'fix' file and copied it to the required folder in path but still would not install! Just gave up and resorted to Acad 2010 which installed fine and runs perfectly - anybody managed to load Arch 2010 on Win 7 without the offending rollback scenario? Quote Link to comment Share on other sites More sharing options...
bradbb2005 Posted December 6, 2009 Share Posted December 6, 2009 Win 7 Pro 64B here with 2010, and it works great this is on a laptop too 1.8Ghz Dual Core ,4GB ram...no problems here Quote Link to comment Share on other sites More sharing options...
Danny Posted December 8, 2009 Share Posted December 8, 2009 Windows 7 using 2010 Mechanical, Very happy with the OS and Acad. A little time to get used to the different symbols and interface, but after that, it is IMHO the most effecient OS and version of acad available. Exceptional improvements in all areas. And yes I used the ribbon Quote Link to comment Share on other sites More sharing options...
ntptorres Posted December 8, 2009 Share Posted December 8, 2009 :shock:Yes...is thru..no problems using Autocad with W7 64 Bit Pro...it work so far very good...Im very glad...so satisfy with this operative system that help autocad to work so fast.....so fine....try it..!!!! I learned on my gaming forum that 7 has an "xp" option. I believe settable to certain EXE files. The concensus was that it was put in for business apps, and not gaming. But ACAD uses OpenGL and DirextX like games do. We have som CAD guys there, but no one was on 7 yet. One guy did upgrade to 7 but had to reinstall all his software. One of the guys had a seperate joystick configuration that during install wouldn't work. 7asked him if he wanted it fixed, he said yes, and it fixed it Quote Link to comment Share on other sites More sharing options...
Jio098 Posted December 9, 2009 Share Posted December 9, 2009 i recently tried autocad on windows 7 and in my opinion it was a bit slow....dont know if it was a problem of autocad or windows 7 but it seemed slow to respond.. Quote Link to comment Share on other sites More sharing options...
Currahee Posted December 10, 2009 Share Posted December 10, 2009 Plan for the future. You don't intend on staying with AutoCAD 2006 forever do you? ADT 2006....yes...cant stand Achitecture 2010...maybe one day if I ever have to upgrade OS Quote Link to comment Share on other sites More sharing options...
TruViet911 Posted December 15, 2009 Share Posted December 15, 2009 I'm running Windows 7 x64 with AutoCAD 2010 and have not had any problems. also running windows 7 x32 with AutoCAD2004 no problems found. Quote Link to comment Share on other sites More sharing options...
Tankman Posted December 30, 2009 Share Posted December 30, 2009 "Windows 7 is supported in AutoCAD 2010 (and 2011 and higher) and Inventor 2010 (and 2011 and higher). If you want to install and run older versions of AutoCAD, LT, or Inventor (2009, 2008, 2007, 2006, R11...) in Win7, you can use the virtualized "XP Mode" available for Windows 7 Professional, Ultimate and Enterprise (both 32-bit and 64-bit). To use the Windows XP Mode you will need a CPU hardware support. You can detect the HW virtualization support in your processor with the utility havdetectiontool.exe . The Windows XP Mode add-on (application) can be downloaded from the Microsoft web. Then you can install the tool through Windows Virtual PC > Windows XP Mode." Quote Link to comment Share on other sites More sharing options...
amit87 Posted January 12, 2010 Share Posted January 12, 2010 i use windows 7 x64 with x64 autocad 2009, works a gem! Quote Link to comment Share on other sites More sharing options...
Newfie Bill Posted January 20, 2010 Share Posted January 20, 2010 Hi amit87! Did you upgrade to Windows 7 after you had installed AutoCAD? Also, from what version of Vista did you upgrade from? Thanks. Quote Link to comment Share on other sites More sharing options...
ntptorres Posted January 21, 2010 Share Posted January 21, 2010 :D1- upgrade to W7 64 Bit then I installed Autocad 2010 and it work very good...fast.....so I installed the other programas I use...It work great...very satisfy with W7 64 Bit and Autocad 2010... Quote Link to comment Share on other sites More sharing options...
Newfie Bill Posted January 21, 2010 Share Posted January 21, 2010 Hi! Well, I went ahead and upgraded to Windows 7 last night. Here is the outcome, I was a bit concerned that I may have to reinstall LT 2009. Previous: 64bit Vista Home Premium, 64bit AutoCAD LT 2009 installed. HP Computer with 6GB RAM and intel quad core 2.8. New: 64bit Windows 7 Home Premium upgrade. The install when flawlessly, all the previous apps run perfect, including LT 2009. I did have to download two updates, one for the printer and one for the GeForce 9500 CS video card. I have noticed that my AutoCAD runs faster, loads faster, and the refreshing is better. Notes: You will have to reauthorize i-Tunes (it is recommended that you deauthorize before install) If you are using "Windows Mail" in Vista you will have to download "Windows Live Mail" and install. Not to worry, all contacts, mail settings and folders are automatically migrated into "Windows Live Mail". Cheers! Bill .. Quote Link to comment Share on other sites More sharing options...
ntptorres Posted February 12, 2010 Share Posted February 12, 2010 Hello people....Im using W7 64 Bit with Autocad 2010...HEY it work very..very...very..GOOD...Im glad..so you can try too..!!!! I have 500 GB of HD and 8 GB of memory...so ...people you should tryit.... Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 12, 2010 Share Posted February 12, 2010 I could just about say the exact same thing as ntptorres. Just switched to a new-for-me-computer that's running Win7, AC 2010 64-bit, 8GB RAM and a 500GB hard drive (yep...I stole your computer! LOL). So far so good. I've only used it for AutoCAD once so far as I am still in the process of bringing everything over from my old system (files and programs). It is much faster than I thought it would be. Sometimes I regret having to boot up my old computer. Quote Link to comment Share on other sites More sharing options...
arshavin23 Posted March 5, 2010 Share Posted March 5, 2010 Im using 2010 and having not had one bit of bother! Quote Link to comment Share on other sites More sharing options...
RageBg Posted March 10, 2010 Share Posted March 10, 2010 Hello , I'm using Autocad 2008 and windows 7 64-bit. I have i major problem , i can't make any plot files , i tried a lot of different drives but no luck so far. At first Autocad made files that were 0 kb , after installing a different driver the program made a normal file but the file was blank. I'm trying drivers for HP DesignJet 800 , designjet 500 with drivers downloaded from HP official site made for windows 7 64-bit. Please if someone can help me PM-me or write here , 10x. Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 10, 2010 Share Posted March 10, 2010 Is AutoCAD 2008 32-bit? I take it you have a HP DesignJet plotter right? When did the problem first occur? Were you ever able to print at all? You might have better luck if you close AutoCAD, uninstall the printer and shut down your computer. Then start up your printer first, followed by turning on your computer, configure your printer in Windows and after doing that load AutoCAD. Does AutoCAD recognize the printer? Quote Link to comment Share on other sites More sharing options...
RageBg Posted March 10, 2010 Share Posted March 10, 2010 Actually i dont have a printer , i just want to make plot files and then print them at a printing studio , my autocad is 64-bit , i cant install on win 7 , 32-bit autocad i tried . I also tried restarting , changing drivers , even drivers for vista 64 bit , still no luck. Autocad has some problem with sone drivers cause when i select the printer to drive in autocad , the windows crushes and windows asks me if i want to close the window. The whole problem occured when i installed win 7 , also my girfriend as vista and she has the same problems with plot files. But she has Xp and Vista both , and she can make plot files on Xp but not on Vista. Something is really ****ty about the whole thing. I still can't find the problem. Pls HELP. Thanks. Quote Link to comment Share on other sites More sharing options...
