a1harps Posted February 21, 2010 Share Posted February 21, 2010 Here I have subtracted the inner solid from the larger solid to create the finished solid wall. Quote Link to comment Share on other sites More sharing options...
a1harps Posted February 21, 2010 Share Posted February 21, 2010 Here I have sliced the solid wall @ the pitch of the building. Not shown is that I had to switch from this SW isometric view to front view in order to do the slice. I wish I knew how to do it while still in SW? Quote Link to comment Share on other sites More sharing options...
a1harps Posted February 21, 2010 Share Posted February 21, 2010 Just for kicks I added the round window at the location show in the original drawing. I used a circle command and then extruded it and subtracted it. Again I had to switch to front view. I realize that the DUCS could have been used to make the circle while in SW isometric view here but I wanted to stay with what can be done in V-2004 Quote Link to comment Share on other sites More sharing options...
Crazy J Posted February 22, 2010 Share Posted February 22, 2010 Rider indicates using 2004. No Extrude line or Slice with surface. That's too bad. I read about extruding a line like that and thought I would try it that way next time. I remembered that in older versions (I'm 2002), I need to slice by defining a plane, but was hoping that by extruding a line, you'd end up with a rectangle and then be able to pick the corner points. These newer commands would save some steps though, as now I have to do some construction lines and offsets to create at least the 3 points on the plane I need to define where I would want to slice. Oh well . . . one more reason I want updated software! Quote Link to comment Share on other sites More sharing options...
Crazy J Posted February 22, 2010 Share Posted February 22, 2010 I think it has a lot to do with the history of CAD - how the author first learned. Most books start of like a first grader connecting dots (grid and snap). I turned that off in my second class back in 1987. That idea makes sense. And I too can't stand the grid and snap feature. I was amazed at the number of books and tutorials out there on every single release of AutoCAD when I had to dive into this a couple months back. I understand that in creating a new book each year or so, the authors may not have time to restructure the whole book, but perhaps a better contrast/comparison of the two approaches would be a useful addition to these books. Quote Link to comment Share on other sites More sharing options...
a1harps Posted February 22, 2010 Share Posted February 22, 2010 Question for ReMark, I hadn't used slice with the "surface" option before so after seeing your example I played with it some. I am trying to understand when it works better than plain old slice...situations you find it ideal? I did discover by accident that I could slice partway through an object by extruding the line to a dimension with less depth than the object being sliced. That definitely gives me ideas. -Thanks Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 22, 2010 Share Posted February 22, 2010 I have to admit that it was JDM that put me on to Slice using the Surface option. Before that I used to use the 3-point option. Quote Link to comment Share on other sites More sharing options...
