Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
    Junior Member
    AutoCAD LT 2010
    Jul 2009
    14
    Question How to completely delete a table data link
    Using AutoCAD 2010 LT with service pack 1 and 2
    I created a link to an Excel file to create a table. Before I ETransmit the AutoCAD file (along with many other files) I want to remove the link so that the table is embedded with no need for the external file. When I have somebody who doesn't have the linked file on their machine open the file they get a "missing external file" message" despite the fact that I ran the detach data link command and have purge selected in the ETransmit setup. The table shows up with the data, but I want to eliminate the nag pop up about the missing file. I know you can click the ignore button, but I don't want our customer to have to bother with it.
    By the way does anyone know a way to save a list of files for ETransmit like you do in a .dsd file for batch plotting?
    Senior Member Tommy78's Avatar
    Tommy78's Computer Details
    Win XP
    AutoCAD 2009
    Feb 2009
    Antwerp/Belgium
    147
    to remove the datalink from your xref manager:
    1) rename or remove the linked .dxe files
    2) copy/paste this:
    Code:
    (dictremove (namedobjdict) "ACAD_DATALINK")
    in the commandline, ENTER
    3) save and close the drawing, reload drawing
    this works in 2009, don't know if it works in 2010
    Forum Newbie
    Architecture 2010
    Aug 2010
    1
    wow that is awsome. My only question is what exactly does it do? dictremove=? namedobjdict=? should there not be a way to do this with standard acad commands?
    Forum Newbie
    Electrical 2012
    Oct 2011
    1
    Default Same Problem With ACAD Electrical 2012
    I am having the same problem as described above. I am using AutoCAD Electrical 2012. I need to completely delete a Data Link for an external Reference File. I tried the tip above in this thread, but my 2012 version says "Unknown Command" in the command line... it does not recogize this remedy from earlier versions...
    Can anyone help me delete this Data Link / Reference File?
  5. #5
    Super Member irneb's Avatar
    irneb's Computer Details
    Win7 Pro 64bit
    Antec One Hundred
    ASUS P8P67-Pro P67
    Intel i7 2600 @ 3.4GHz
    16GB-1600MHz
    GeForce GT 430 (1GB)
    Seagate1TB SATA2 - 7200rpm
    Samsung 2333TN 23" 1920 x 1080 Full HD LCD Monitor2GW
    Architectural
    irneb's Discipline Details
    Architectural Technician and Programmer
    Architectural
    AutoCAD 2013
    Sep 2010
    Jo'burg SA
    1,744
    Data links are stored inside the drawing file as dictionary objects. That line which Tommy gave is a lisp which deletes the entire link dictionary - i.e. removes all data links. Most links disappear of their own, or you can delete them through the DataLink command. Some don't want to play well though. If you want a more fine-grained control, you could try my DictEdit routine here: http://forums.augi.com/showthread.php?t=78139
    Knowledge is proportional to experience, but wisdom is inversely proportional to ego!
    My little bit of "wisdom": Hind-sight is useless, unless used to improve the next forethought!
  6. #6
    Forum Newbie
    Inventor 2011
    Jul 2012
    3
    Quote Originally Posted by Tommy78 View Post
    2) copy/paste this:
    Code:
    The only problem with this is that Autocad LT cannot run lisp commands. I'm running the exact same version as the O.P. and having the same issues.
  7. #7
    Senior Member
    Manufacture
    eyde's Discipline Details
    Project Manager/ Regional CAD Manager
    Manufacture
    We manufacture concrete utility vaults
    AutoCAD 2015
    Sep 2010
    Back in Texas
    107
    Just type in XREF and the dialog box will come up. Detach all of your data links in the dialog box. Now your good to go.
  8. #8
    Forum Newbie
    Inventor 2011
    Jul 2012
    3
    The X-ref palate will not let you remove data links.
    And the problem we are having is the actual deletion. I've already detached every reference, but when i go to try to delete it, it gives the error stating it is still referenced somewhere.
  9. #9
    Senior Member
    Manufacture
    Manufacture
    AutoCAD 2015
    Sep 2010
    Back in Texas
    107
    I am sorry that did not work for you.
    I use tables all day long and I just detach the data link by selecting a cell right click and go to detach data link which makes my table just text.
    Then I go to the xref manager and select the data link right click select detach.
  10. #10
    Win7 Pro 64bit
    Antec One Hundred
    ASUS P8P67-Pro P67
    16GB-1600MHz
    Architectural
    Architectural
    AutoCAD 2013
    Sep 2010
    Jo'burg SA
    1,744
    If that doesn't work and you can't use lisp (i.e. on LT), then try doing a WBlock (with Entire Drawing checked). As long as there's no tables attached to a datalink, this should make a new duplicate DWG file without any datalinks in it. Just make sure you've detached all data links from all tables (as Eyde's explained) before doing the wblock.
    Note wblock does much more than detatch datalinks, it's one of the oldest methods for cleaning a DWG file. Usually it cleans it better than you can accomplish with purge & audit only. This is both good and bad, e.g. while all the usual stuff gets "purged", unexpected purges also happen like unused Page Setups are cleared.
  1. adding data to polyline and extracting this data to table?
    By feargt in forum AutoLISP, Visual LISP & DCL
    Last Post: 24th May 2013, 08:04 pm
  2. Replies: 2
    Last Post: 19th Aug 2009, 02:40 pm
  3. Excel Table Data Link
    By johnv in forum AutoCAD General
    Last Post: 31st Jul 2009, 12:11 am
  4. How can I edit a Table Data Link Value via VBA or LISP?
    By PJF in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Feb 2009, 03:28 pm
  5. Edit Table with Data Link
    By Tconn in forum AutoCAD General
    Last Post: 25th Sep 2008, 02:20 pm
