SLW210 Posted April 10, 2015 Posted April 10, 2015 It's a two step process. The table needs to be deleted, then the datalink removed. Please reread this thread, that does not always work. (See post #4) These other solutions are for when that doesn't work. Plenty of these threads on Autodesk knowledge base, AUGI and other AutoCAD Forums. Quote
RobDraw Posted April 10, 2015 Posted April 10, 2015 TBH, I had trouble following this thread and was just offering up something that I didn't see mentioned or may help some of the people with the "same" problem. Quote
sandra142 Posted April 29, 2021 Posted April 29, 2021 Here is the guide that will help you out to find/remove link from Excel workbook using the Broken Links option. Here is the link from which you can get this immediate help. http://www.repairmsexcel.com/blog/excel-broken-links Quote
featherNfur Posted February 26, 2024 Posted February 26, 2024 FYI, this just worked for me in C3D 2024 when an unused datalink would not delete stating that it was in use. (dictremove (namedobjdict) "ACAD_DATALINK") at command line save, close, reopen Quote
