Results 1 to 6 of 6
    Forum Newbie
    AutoCAD 2010
    Nov 2010
    3
    Default 3d polyline wireframe to solid
    Hi,
    I'm new to this forum but have been following it for awhile and think it is an invaluable exchange network.
    I'm stuck on how to convert my model to a 3d solid, i have it as a mesh model in rhino, and lines and 3d polylines in autocad. region + extrude (press pull) doesn't work. i can't offset it = it says points are not in same plane. I don't know what to do....please help!
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,729
    That's one of the problems encountered with doing something in one program and then bringing the output into another. Sometimes you just create more headaches for yourself.
    AutoCAD does have a mesh-to-solid conversion command but I'm not 100% sure it will work in your case. But you should at least give it a try. Click on the Mesh Modeling tab, find the Convert Mesh panel and click on Convert to Solid. What happens?
    Forum Newbie
    AutoCAD 2010
    Nov 2010
    3
    ReMark,
    Thank-you so much for your reply. It seriously is a big headache. But I would love to get it to work so I can put it into revit 2011. I tried convert mesh but it would not work because it said I had open meshes - ie gaps. I am trying to resolve this but in rhino, there are no gaps!!! i also used the highest mesh triangulation output. there is also a convert solid command in rhino 4 but i couldn't get that to work either. I will keep trying! i have got to get inventive I think!
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,729
    I think you painted yourself into a corner and you are not going to get out.
  5. #5
    Full Member
    AutoCAD 2010
    Oct 2015
    27
    hello
    was reading this thread
    i have same exact issue..
    I have 3 D polylines i need to convert to 3D solids.
    -CONVOTOSOLIDS does not work
    can you advice on anythig which can make me do the conversion easily? i have more than 1000 shapes..
    thanks heaps
    kay
  6. #6
    Full Member
    AutoCAD 2010
    Oct 2015
    27
    Quote Originally Posted by whiterabbit View Post
    ReMark,
    have you found a solution to this issue..?
  1. 3D wireframe to 3D solid?
    By acce in forum AutoCAD 3D Modelling & Rendering
    Last Post: 19th Sep 2009, 12:32 pm
  2. 3D solid to Wireframe
    By Wise in forum AutoCAD 3D Modelling & Rendering
    Last Post: 3rd Nov 2008, 08:25 pm
  3. Converting a wireframe to solid
    By AutoNewbie in forum AutoCAD 3D Modelling & Rendering
    Last Post: 17th Mar 2008, 02:08 pm
  4. wireframe to solid
    By 911racer in forum AutoCAD Drawing Management & Output
    Last Post: 18th Jul 2007, 02:45 am
  5. wireframe to solid?
    By bop in forum AutoCAD 3D Modelling & Rendering
    Last Post: 30th Oct 2003, 11:10 pm
