block place near of the end of line
Guest cad2007
in line end we can possible to fix the block..like i am selecting one line,its need to take which side is near end that side my given ""block"" need to be place.....
  • Replies 29
  • alanjt
    9
  • Tharwat
    7
  • mdbdesign
    5
Posted Images
ummmm.....what?
Due to an obvious language barrier, post an image/drawing showing the before and after result.
Guest cad2007
ummmm.....what?
Here i have attached one image....i am selecting one line means its need to measure from center and which side near of end(or Start) that side block should be place..After my selection its need to ask block name.After we r giving block name means irs need to be place.....
[ATTACH]24298[/ATTACH]
Are you also selecting the block to 'insert' at the end/start point?
Guest cad2007
in that time i cannt able chk which one start or which side end...in that time From center its need to consider nearest start(or end) points....
Like i am selecting one line so its consider that nearest start or end of line....
You can use vlax-curve-getStartPoint and vlax-curve-getEndPoint and sort with vl-sort, based on shortest distance the given point and the end/start point, then just take the first item in the list.
eg.
(car (vl-sort (list (vlax-curve-getStartPoint <EName>) (vlax-curve-getEndPoint <EName>))
             (function (lambda (a b) (< (distance <Point> a) (distance <Point> b))))
Guest cad2007
here hw to fix the defun command...???and for block asking?
What about just selecting endpoint and rotate?
Guest cad2007
its showing error.; error: An error has occurred inside the *error* functionAutoCAD
variable setting rejected: "filletrad" nil..
with comand only we can acess..??other wise we cannt use
You may find these codes helpful . :)
(defun c:THib (/ ss start end e lst answer)
 ; THARWAT Nov.02.2010
 (if (setq ss (car(entsel "\n Select Line :")))
     (setq start (cdr (assoc 10 (setq e (entget ss)))))
      (setq end (cdr (assoc 11 e)))
     (entmakex (list (cons 0 "INSERT")
		(cons 2 "[b][color="red"]YourBlockName[/color][/b]")
		(cons 10 start)
             (setq lst (entlast))
                 (initget "Yes No")
                    (setq answer (getkword "\n Agree with this side [Yes/No] :"))
                      (if (eq answer "No")
                   (entdel lst)
		      (cons 10 end)
		      (cons 50 3.14159)))
Tharwat
Guest cad2007
i have tried...but there is no option for block insert...and one more here Agree with this side i am given no means its deleting mt selected line....So here i want to fix block insert option.which block i am giving that block need to place in nearest start or end of the line..........
Try this, no defun reqired
^C^C-insert;\end;\;;\
It give you option to select closest end and rotation
Just insert the name of your block , then load the routine .
*Codes are updated with name of Block*
Tharwat
Guest cad2007
i want to add this to this codes???where i want to add??this??
Seriously?!? So, basically, you have no coding experience and you are just wanting handouts.
           (cons 2 "[b][color=red]YourBlockName[/color][/b]")
           (cons 10 start)
                 (initget "Yes No")
                      (entdel lst)
                 (cons 10 end)
                 (cons 50 3.14159)))
Tharwat
You can save some headache by just entmod'ing the insertion point instead of deleting and recreating.
Button......
Create new button, add above macro to it and use.
Guest cad2007
i have tried..its placinfg the block to line start only...please try once..i want to nears(start or end)as per the selection....
