bengee54 Posted January 14, 2011 Share Posted January 14, 2011 hi, I've got a small problem; on the attached jpeg you will see a housing (shown in black) and a pipe inserted from underneath. how can i trim the material (of the inserted pipe) so that its flush with the hole in the bottom of the housing i.e. so nono is visible when looking through the housing)? somebody please help! Thanks Ben Quote Link to comment Share on other sites More sharing options...
JD Mather Posted January 14, 2011 Share Posted January 14, 2011 I'm not familiar with trimming in jpegs - zip and attach you assembly here. Quote Link to comment Share on other sites More sharing options...
bengee54 Posted January 14, 2011 Author Share Posted January 14, 2011 i use Inventor 2010. i've tried to attach the zip file, but its too large. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted January 14, 2011 Share Posted January 14, 2011 i use Inventor 2010. i've tried to attach the zip file, but its too large. Roll up the part EOPs first. Quote Link to comment Share on other sites More sharing options...
danielk Posted June 21, 2015 Share Posted June 21, 2015 I know its an old post , but does anyone found a way to solve this ? Thanks Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 22, 2015 Share Posted June 22, 2015 I dont use inventor but it should be the same as in Autocad just some suggestions 1 subtract an amount from the pipe at the flange height maybe a trim type command in Inventor 2 move the end centre of pipe to the centre of the flange if length is not critical. 3 shorten pipe to correct length using properties Quote Link to comment Share on other sites More sharing options...
lulumara Posted June 24, 2015 Share Posted June 24, 2015 Is this in Assembly files or just in Part files? If Assembly files , you can use constrain- joint(Inventor2016 version) /gap( before using this measure the extra length (command is distance) you need to move in order to flush at the bottom of hole) examples = -.25" or 1/4" or + 0.25" just play around to see it flush to the bottom. If a part files-- use sketch to plane parallel to the hole housing/ then extrude cut in order to remove the pipe excess you are seeing. Quote Link to comment Share on other sites More sharing options...
