Raudel Solis Posted April 16, 2011 Share Posted April 16, 2011 oh no that shows how to uninstall ALL AUTODESK SOFTWARE. even if you dont use windows uninstall program. deleting the registry valueS mention in JDM's post will somewhat disable ALL autodesk products installed because it will delete all autodesk product registry read jdm's link post title Quote Link to comment Share on other sites More sharing options...
Cad64 Posted April 16, 2011 Share Posted April 16, 2011 ma7amadk, have you solved your problem yet, or do you still require further assistance? Please let us know. Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 16, 2011 Share Posted April 16, 2011 oh no that shows how to uninstall ALL AUTODESK SOFTWARE. even if you dont use windows uninstall program. deleting the registry valueS mention in JDM's post will somewhat disable ALL autodesk products installed because it will delete all autodesk product registry read jdm's link post title I think you misread it. Try again. Quote Link to comment Share on other sites More sharing options...
ma7amadk Posted April 17, 2011 Author Share Posted April 17, 2011 ma7amadk, have you solved your problem yet, or do you still require further assistance? Please let us know. unfortunately not yet, I was tried yesterday to setup AutoCAD on another PC and it's asked me to update .Net from 1.1 then clicked update, maked extracting by itself then restarted PC and tried again and it finished successfully. I tried all advices in this thread on my laptop but..... I'll make an image of my system and setup win 7 again then I'll try AutoCAD setup after that. Quote Link to comment Share on other sites More sharing options...
Raudel Solis Posted April 17, 2011 Share Posted April 17, 2011 if you click link to autodesk site it will have "How to remove all Autodesk software products from a system to ensure a clean install" "all" you missed the point but thats ok Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 17, 2011 Share Posted April 17, 2011 What-ever dude. Quote Link to comment Share on other sites More sharing options...
Organic Posted April 18, 2011 Share Posted April 18, 2011 I think you misread it. Try again. I disagree. If you were to follow those instructions " Remove any remaining Autodesk files: In Windows Explorer, delete the installation folder for each Autodesk product that was uninstalled in the previous procedure (for example, C:\Program Files\AutoCAD 2008). Delete the C:\Program Files\Common Files\Autodesk Shared\ folder. Note: If your operating system is configured to store the Program Files folder on a drive other than C:, the path will be on that drive. Delete the following user profile folders: Windows XP C:\Documents and Settings\%username%\ Application Data\Autodesk C:\Documents and Settings\%username%\Local Settings\Application Data\Autodesk C:\Documents and Settings\All Users\Application Data\Autodesk Windows Vista/Windows 7 C:\Users\%username%\AppData\Roaming\Autodesk C:\Users\%username%\AppData\Local\Autodesk C:\ProgramData\Autodesk" it would render all Autodesk installed programs inoperable, with a Repair or reinstall of them required. Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 18, 2011 Share Posted April 18, 2011 You still don't get it but that's OK. It's not worth explaining. Quote Link to comment Share on other sites More sharing options...
Cad64 Posted September 21, 2011 Share Posted September 21, 2011 Any advice? Yes. Stop using pirated software and purchase a legal copy of the program. Quote Link to comment Share on other sites More sharing options...
khoshravan Posted September 28, 2011 Share Posted September 28, 2011 if you have more than 1 version of autocad installed you must be careful I have the same problem. It is as follows: I have AutoCAD2007 installed in my drive C. It is fine with no problem. I tired to install AutoCAD2010 on drive C as well (Drive C was chosen accidentally and I didn't want to cancel the installation process in the middle). I failed to install. Now my laptop says me that there is no enough space and delete some files to empty the space. I can see AutoCAD 2010 folder in C which has consumed 1.8 Gb of space but I can't see any otherdata related to AutoCAD 2010 neither in Control Panel(Add/remove) nor in regedit. regedit show data for AutoCAD2007. I want to delete AutoCAD2010 folder entirely and then try to install AutoCAD 2010 in drive D. What is your opinion? My system is: Widows XP Professional Ver. 2002 SP2. Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 28, 2011 Share Posted September 28, 2011 You created a RESTORE point prior to attempting the installation right? Quote Link to comment Share on other sites More sharing options...
khoshravan Posted September 28, 2011 Share Posted September 28, 2011 You created a RESTORE point prior to attempting the installation right? Are you with me? No unfortunately I don't. I was lazy to follow those steps. Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 28, 2011 Share Posted September 28, 2011 Lesson learned I hope. You can just delete the folder and try installing AutoCAD again. How much worse can it get? In the future you might also want to download the free program called Revo Uninstaller too. Quote Link to comment Share on other sites More sharing options...
khoshravan Posted September 28, 2011 Share Posted September 28, 2011 Lesson learned I hope. You can just delete the folder and try installing AutoCAD again. How much worse can it get? In the future you might also want to download the free program called Revo Uninstaller too. Do you recommend to unistall ACAD2010 with Revo? What is its advantage and where can I get it. Another colleague in this thread recommended a link to uninstall all AutoDesk products. Since I have only ACAD 2007 and ACAD 2010, I thought it mught be good to use that solution and delete both CADs and then have a clean install of ACAD 2010. What is your opinion? Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 28, 2011 Share Posted September 28, 2011 You can try but I'm not even sure if it is partially installed let lone fully installed. Revo Uninstaller can be downloaded from the PCWorld website. Sure, wipe them both out. What's to lose? Quote Link to comment Share on other sites More sharing options...
