kippax Posted April 28, 2011 Share Posted April 28, 2011 I have a problem where i have a single block (imported XRef) that contains both the existing external and internal walls of a large office block in model space. However, in a viewport on a paperspace tab representing the proposed layout, only the external walls are visible as the internal walls are to be removed. How have they done this ? The reason I ask is that I need to import the file into lighting software and want the model space to look like the view in paperspace. Obviously if I freeze the layer (as I would normally do) I lose both the internal walls to be removed along with the externals and this is no use to me. Have I made sense ? Quote Link to comment Share on other sites More sharing options...
SLW210 Posted April 28, 2011 Share Posted April 28, 2011 Hard to say without seeing the file and viewport settings. My initial GUESS would be a wipeout. Quote Link to comment Share on other sites More sharing options...
