kippax Posted April 28, 2011 Posted April 28, 2011 I have a problem where i have a single block (imported XRef) that contains both the existing external and internal walls of a large office block in model space. However, in a viewport on a paperspace tab representing the proposed layout, only the external walls are visible as the internal walls are to be removed. How have they done this ? The reason I ask is that I need to import the file into lighting software and want the model space to look like the view in paperspace. Obviously if I freeze the layer (as I would normally do) I lose both the internal walls to be removed along with the externals and this is no use to me. Have I made sense ? Quote
SLW210 Posted April 28, 2011 Posted April 28, 2011 Hard to say without seeing the file and viewport settings. My initial GUESS would be a wipeout. Quote
