I still haven't gotten a straight answer to this question posted on Wednesday, 08-31-2011:If it can be done, I would like step by step instructions, if it can't be done then let me know.Can you chamfer a circle (used the ellipse command) in an isometric drawing, if so, how is it Done?
Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
I thought the question was answered as well.
Post an image of what you're working on.
Eat brains...gain more knowledge!![]()
Tony, FWIW - some may interpret the *tone* of your last post as being impatient, and/or rude.
Typically when someone *talks* that way, I choose to respond by asking them to tell *us* what happens when they attempt this themselves. Not knowing for sure, I am willing to give you the benefit of the doubt.
Now, perhaps this will help to clarify:
CT_chamfer.pngCode:Command: cha CHAMFER (TRIM mode) Current chamfer Dist1 = 0.0000, Dist2 = 0.0000 Select first line or [Undo/Polyline/Distance/Angle/Trim/mEthod/Multiple]: <SelectsLine> Select second line or shift-select to apply corner: <SelectsEllipse> Cannot chamfer between these two entities.
By definition a circle is not an ellipses, nor a cylinder, sphere, or the like. Perhaps a little more acuracy in the question's wording, or even a sample drawing being posted will yield the desired result more quickly in the future.
HTH
"Potential has a shelf life." - Margaret Atwood
AutoCAD, and Civil 3D Certified Professional | Autodesk Authorized DeveloperSincpac C3D ~ Exchange Apps ~ Autoloader ~ AutoCAD Security
Here is a step by step instruction
Type chamfer in commandline then press F1
It TELLS exactly what you can chamfer.
As far as Isometric what difference does that make besides using ellipses to represent circles.
I guess since you are supposed to use ellipses to represent circles in a isometric drawing your asking can you use chamfer on a ellipse?
The definition of Chamfer
A chamfer connects two objects to meet in a flattened or beveled corner.
A chamfer connects two objects with an angled line. It is usually used to represent a beveled edge on a corner.
You can also find your answers @ theswamp.org
TonyD
It can be done.
TonyD, another method here:
I still don't quite get the question that is being asked as it is the shortest explanation of what is trying to be achieved that I have seen so far but if the above posts don't answer the question then I'm completely lost.
A straight answer:
A circle in isometric drawing is represented by an ellipse. Neither ellipse nor circle can be chamfered.
It is assumed here that the OP meant a cylinder rather than a circle or an ellipse. So far, OP didn't confirm that to be the case.
It is very common in this forum that the OP forces the people here to guess what he/she means by being either extremely brief, inaccurate or expressing himself/herself incomprehensively.
