Page 5 of 5 FirstFirst ... 3 4 5
Results 41 to 50 of 50
  1. #41
    Full Member ConfusedStudent's Avatar
    AutoCAD 2013
    Jan 2015
    Montana
    40
    Hondatek look at this thread. It may help you.
  2. #42
    Senior Member
    Hondatek's Computer Details
    Win7
    dell T5400, dell optiplex 745
    AutoCAD 2013
    Oct 2014
    Houston, Tx
    113
    i'm looking
  3. #43
    AutoCAD 2013
    Jan 2015
    Montana
    40
    First, set a running OSNAP to NODE.
    Use the PEDIT command to establish the properties of
    each contour line.
    1. Select each polyline, choose the Ltype option, and
    then choose the On option. Doing so makes the
    hidden linetype properties visible even if the line
    segment isn’t very long.
    2. For all contour lines except those marking the
    70-foot, 80-foot, and 90-foot intervals, also choose
    the Fit option for each polyline. Doing so will allow
    the polyline to curve between node points.
  4. #44
    Senior Member
    Win7
    AutoCAD 2013
    Oct 2014
    Houston, Tx
    113
    This is where im having problems finding how to set up. Ill work on it at home
  5. #45
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,643
    What do you mean by "how to set up"?
    Your contours are using the linetype called HIDDEN which means they should appear dashed on your screen.
    Your OSnap settings should have NODE enabled (for picking points).
    If you have drawn all your contours using a polyline and they are currently being displayed as straight line segments between points, by running the PEDIT command and selecting a polyline then the FIT option the polyline will be fitted with a curve that passes through each point.
  6. #46
    Senior Member
    Win7
    AutoCAD 2013
    Oct 2014
    Houston, Tx
    113
    REMARK i posted a screenshot. i have that set up already. OSnap settings should have NODE enabled. done this is what I don't think I did.
    follow me?
  7. #47
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,643
    Top: Polyline - continuous - straight segments.
    Middle: Polyline - hidden - straight segments.
    Bottom: Polyline - hidden - Curve fitted.
  8. #48
    Full Member
    Architecture 2017
    Feb 2016
    athens,georgia
    27
    Hey HARPAL im trying to complete the same project and im stuck on plates 3 and 4, do u have those plates so that i could study them and get an idea of how to complete them? I would be forever grateful for any help. Thanks.
  9. #49
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,643
    HARPAL hasn't been around since March 5th, 2014. I doubt you'll get a response from him.
    This project has been the topic of several threads so I would suggest you first find and read them. I'm sure a couple of them have images of plates 3 and 4.
    I just noticed that post #40 of this thread has what appears to be a link to another thread where images of plates 3 and 4 can be viewed. I think you failed to fully read this thread before posting you question. I realize some of these P-F threads can be quite long but don't just skip to the end of the thread without first reading through it. You never know what you may find.
  10. #50
    Full Member
    Architecture 2017
    Feb 2016
    athens,georgia
    27
    Ok I'll look at the other threads remark thanks
  1. Penn Foster Drafting with Autocad
    By sethtb1 in forum Student Project Questions
    Last Post: 27th Dec 2012, 05:02 pm
  2. Penn and Foster Structural Project Help
    By robxfinch in forum Student Project Questions
    Last Post: 20th Nov 2011, 03:31 am
  3. Penn Foster Oleson Village project
    By bracken2 in forum Student Project Questions
    Last Post: 1st Aug 2011, 04:07 pm
  4. Structural drafting project Plate 2 (penn foster)
    By ANC2008 in forum Student Project Questions
    Last Post: 13th Jul 2011, 11:47 pm
  5. Penn Foster help with HVAC/sheet metal Drafting
    By paisis123 in forum Student Project Questions
    Last Post: 15th Jun 2011, 10:19 pm
