jimpcfd Posted March 26, 2012 Share Posted March 26, 2012 hi all is it possible to create and load a Layer in acaddoc file, i have a layer that i use in most of our drawings called EDGE, it's color needs to be red, continuous line type and 0.0 lineweight, no bylayer in it. can anyone help ? thanks jimpcfd Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 26, 2012 Share Posted March 26, 2012 It would be better to put this layer that you use in most of your drawings in your drawing template (DWT). So much easier. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted March 26, 2012 Share Posted March 26, 2012 Put this into your acaddoc.lsp (if (not (tblsearch "LAYER" "EDGE")) (entmake (list '(0 . "LAYER") '(100 . "AcDbSymbolTableRecord") '(100 . "AcDbLayerTableRecord") '(2 . "EDGE") '(6 . "Continuous") '(62 . 1)'(370 . 0) '(70 . 0) ) ) ) Quote Link to comment Share on other sites More sharing options...
MSasu Posted March 26, 2012 Share Posted March 26, 2012 For sure the template solution sugested by ReMark is better; if still want to add it programatically: (entmake '((0 . "LAYER") (100 . "AcDbSymbolTableRecord") (100 . "AcDbLayerTableRecord") (2 . "EDGE") (70 . 0) (62 . 1) (6 . "Continuous")) ) Regards, Mircea Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 26, 2012 Share Posted March 26, 2012 Both lisp routines are overkill. Put the layer in your template. It will always be there whether you need it or not. And if it really bothers you to have a layer that is not referenced then purge it along with all the other unreferenced entities. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted March 26, 2012 Share Posted March 26, 2012 Both lisp routines are overkill. Put the layer in your template. It will always be there whether you need it or not. Using a template will ensure the Layer is available in new drawings, but the layer will still not be accessible in existing drawings. Creating the layer using the ACADDOC.lsp will ensure the Layer is available in both new and existing drawings. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted March 26, 2012 Share Posted March 26, 2012 I would use something like this: ( (lambda ( data / ent ) (if (setq ent (tblobjname "LAYER" (cdr (assoc 2 data)))) (entmod (cons (cons -1 ent) data)) (entmake data) ) ) '( (0 . "LAYER") (100 . "AcDbSymbolTableRecord") (100 . "AcDbLayerTableRecord") (70 . 0) (2 . "EDGE") (6 . "Continuous") (62 . 1) (370 . 0) ) ) The above will create the Layer if it doesn't already exist in the drawing, or if it does exist, will modify the existing layer properties to match those required. Quote Link to comment Share on other sites More sharing options...
jimpcfd Posted March 26, 2012 Author Share Posted March 26, 2012 i tried the DWT file options but, as Lee has said, the problem comes when you are using DXF's from other systems, as we do a lot. of cause we could type dxfin all the time but , it's so much easier to just click on the file. i didn't know that you could put Vlisp methods in acaddoc? thanks tharwat,msasu and of cause Lee, i will have a play and see what's best for me. thanks Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted March 26, 2012 Share Posted March 26, 2012 You're very welcome jimpcfd Note that the ACADDOC.lsp is simply like any another LISP file, except that it will load automatically for every drawing opened because of its filename. When a drawing is opened, AutoCAD is programmed to search the Support File Directories and Working Directory (searches here first) for any LISP file named "ACADDOC.lsp" and will load the first one that it finds. Hence, the ACADDOC.lsp can contain the same LISP expressions as any other LISP file. The ACADDOC.lsp could contain a whole program itself, or even multiple programs. However, it is usually far more manageable and maintainable to load programs from other LISP files via load expressions (these are also LISP expressions themselves) in the ACADDOC.lsp, so that each program has its own .lsp file. Lee Quote Link to comment Share on other sites More sharing options...
SLW210 Posted March 26, 2012 Share Posted March 26, 2012 You could also load a layer with a button macro. Just click and layer created. [size=2][color=black]^C^C_-layer;make;edge;color;red;;ltype;continuous;;lweight;0.0;;;[/color][/size] You can also use tool palettes (my preference) and design center, I just prefer to load layers as needed. Quote Link to comment Share on other sites More sharing options...
jimpcfd Posted March 27, 2012 Author Share Posted March 27, 2012 hi All, many thanks the only problem i get is that the layer is a bylayer colour, which for us is a nightmare, as on of out CNC machines when reading a DXF file defaults all bylayer colours to white. is there a way around this, can the layer have a colour that is not linked to the bylayer ? thanks jimpcfd Quote Link to comment Share on other sites More sharing options...
MSasu Posted March 27, 2012 Share Posted March 27, 2012 So, are you saying that the entities from said layer EDGE had the color set as ByLayer and this isn't interpreted well by your CNC? Therefore you want to have the color set directly on entities. I'm afraid there is no way to control that from layer; what you can do instead is after the sketch is done use QSELECT to gather all entities from that layer and fix their color to red. Or, it you are looking to automate this step you can redefine the SAVE command to add the run of a small AutoLISP routine that will perform that fix prior to save. Regards, Mircea Quote Link to comment Share on other sites More sharing options...
pBe Posted March 27, 2012 Share Posted March 27, 2012 cecolor 1? Quote Link to comment Share on other sites More sharing options...
jimpcfd Posted March 27, 2012 Author Share Posted March 27, 2012 many thanks pBe that cracked it so what does ce mean then? thanks jimpcfd Quote Link to comment Share on other sites More sharing options...
pBe Posted March 27, 2012 Share Posted March 27, 2012 many thanks pBe that cracked it so what does ce mean then? thanks jimpcfd Current Entity Color same goes for Linetypes CELTYPE and Lineweights CELWEIGHT and also for Linetype scales CELTSCALE All system variables, that you can also include on your acaddoc.lsp (setvar 'Cecolor "1") Quote Link to comment Share on other sites More sharing options...
jimpcfd Posted March 27, 2012 Author Share Posted March 27, 2012 thanks again pBe, being able to do that in acaddoc.lsp will be very handy. thanks jmpcfd Quote Link to comment Share on other sites More sharing options...
pBe Posted March 27, 2012 Share Posted March 27, 2012 thanks again pBe, being able to do that in acaddoc.lsp will be very handy. thanks jmpcfd You are welcome. Glad I could help Cheers Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted March 27, 2012 Share Posted March 27, 2012 If your Layers are set up correctly, another option might be to use the following code to set the Colour of all objects to the colour of the Layer on which each resides (not ByLayer): (defun c:SetColours ( / a c e i l s x ) (while (setq a (tblnext "LAYER" (null a))) (setq l (cons (cons (cdr (assoc 2 a)) (cons 62 (abs (cdr (assoc 62 a))))) l)) ) (if (setq s (ssget "_X")) (repeat (setq i (sslength s)) (setq e (entget (ssname s (setq i (1- i)))) c (cdr (assoc (cdr (assoc 8 e)) l)) ) (if (setq x (assoc 62 e)) (entmod (subst c x e)) (entmod (append e (list c))) ) ) ) (princ) ) Quote Link to comment Share on other sites More sharing options...
pBe Posted March 27, 2012 Share Posted March 27, 2012 I supposed a reactor would be too much to ask Lee. For Entity creation commands: i.e. Line, Polyline.... Detect current layer color then set it to CECOLOR will that be overkill Lee? Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted March 27, 2012 Share Posted March 27, 2012 I supposed a reactor would be too much to ask Lee.For Entity creation commands: i.e. Line, Polyline.... Detect current layer color then set it to CECOLOR will that be overkill Lee? Maybe not too much overkill, but certainly very annoying to code since you would have to account for every entity creation command and check the required colour from the current layer, but also allow for when the user changes an entity's layer / colour independently and react on those events too, using perhaps Object Reactors monitoring every entity created... if you want to code it, be my guest Quote Link to comment Share on other sites More sharing options...
