Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 29
    Senior Member
    AutoCAD 2006
    Jan 2008
    Dartmoor, Devon, UK
    192
    Default SCALE different in x and y direction
    I can't believe that in Acad 2006 there's no way to scale an object in one direction only e.g.
    in x direction scale = 1.15, in y direction scale unchanged i.e 1.0.
    Mstation does it - surely there must be at least a workaround in Acad?
    Forum Deity Dadgad's Avatar
    AutoCAD 2012
    Nov 2011
    3,131
    If you wblock it, and insert it as a block you can scale along an axis.
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    2,986
    In addition to what Dadgad said, if you are looking to scale 3D solids by this method, then please pay attention the resulted block cannot be exploded, therefore will not be able to use further the entities.
    Regards,
    Mircea
    AutoCAD's happy user equation: FILEDIA + PICKADD² + PICKFIRST = 3
    Super Moderator Tiger's Avatar
    Tiger's Computer Details
    Windows 7 Enterprise 64 bit
    Dell Precision M4500
    Intel Core i5 2.40GHz
    8GB
    NVIDIA Quadro FX 880M
    280 GB
    2 x Samsung SyncMaster 2443 24''
    AutoCAD 2012
    Nov 2006
    Sthlm, Sweden
    4,595
    Dadgads suggestion works like a charm, but if you don't need to have whatever you need scaled as it's own DWG, its enough to just use the command BLOCK which only creates a block-definition inside the drawing.
    AutoCAD Mechanical has a command that does this built in and yes, it's annoying that it's not in vanilla autocad.
    Life doesn't suck, although we all go through periods when it may be easier to think that, than to discern the solution to whatever problem is the most formidable
    at the moment in one's personal UCS.
    Go to PLAN view instead. - Dadgad
  5. #5
    Senior Member
    AutoCAD 2006
    Jan 2008
    Dartmoor, Devon, UK
    192
    Wow I never knew about WBLOCK, only BLOCK, which I use a lot. Is the only difference that WBLOCK is stored as a separate .dwg, everything else the same?
    But - I can't see how to scale either a BLOCK or a WBLOCK along one axis - I just get offered the same SCALE command without choice of axis.
  6. #6
    Construction
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    2,986
    Quote Originally Posted by fostertom View Post
    You can do that either in Properties, if the block is already insterted, or at insertion time.
    Regards,
    Mircea
  7. #7
    Senior Member
    AutoCAD 2006
    Jan 2008
    Dartmoor, Devon, UK
    192
    Great, I've never dabbled in this.
    But I want to scale my object on an axis that is 45o to the y axis - e.g. a square gets stretched from bott R to top L, but no distances get stretched from bott L to top R, so the square goes kite-shaped. I have tried rotating the square 45o before WBLOCKing, so that as WBLOCKed the y axis is indeed the one I want to stretch - but the stretch still happens to the original y-axis, so the square just goes rectangular.
  8. #8
    Senior Member
    AutoCAD 2006
    Jan 2008
    Dartmoor, Devon, UK
    192
    As you were - it's working now - thanks a lot.
  9. #9
    Forum Newbie
    AutoCAD 2011
    Sep 2012
    3
    Is there any way we can scale in one direction without using block
    I have to use this file for CNC therefore I cannot use explode command
  10. #10
    AutoCAD 2012
    Nov 2011
    3,131
    Welcome to the forum.
    I don't see why you cannot use the EXPLODE command,
    Depending of course on your geometry.
    What types of drawing entities are there in the drawing, which you would need to block?
    Can't you use PEDIT or similar commands after exploding the block?
    Can you upload the drawing, or a representative sample of it?
    Hmmm, I just saw Mircea's note in the earlier post.
    Can you post something as a test?
  1. Scale a block in one way direction (x)
    By Bart80 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 22nd Oct 2010, 02:17 am
  2. Scale in X-direction ONLY
    By feeneyje in forum AutoCAD General
    Last Post: 21st Aug 2010, 07:25 pm
  3. how do you scale graphs in only one direction
    By mark.meyers in forum AutoCAD Beginners' Area
    Last Post: 13th May 2009, 01:52 pm
  4. scale in one direction while keeping the other the same ?
    By blaryon in forum AutoCAD General
    Last Post: 29th Jul 2008, 01:11 pm
  5. Scale From one Direction
    By therock005 in forum AutoCAD General
    Last Post: 20th May 2008, 02:59 pm
