hi all,
I have a plot routine that I use because it updates all fields and purges the drawing before plotting. Can I modify this so that it updates fields throughout the drawing ( as in all layouts) and then plots all layouts.
;Based on PageSetups from Alan J. Thompson
(defun c:A1 ()
(PlotReactorOFF)
 (if (findfile "T:/Drawing Tools/Templates/CCC2009.dwt")
     (command "_.psetupin" (findfile "T:/Drawing Tools/Templates/CCC2009.dwt") "A1")
     (while (wcmatch (getvar "cmdnames") "*PSETUPIN*")
       (command "_yes")
     ) ;_ while
     T
   ) ;_ progn
 ) ;_ if
(command "-plot" "n" "" "A1" "" "n" "y" "n")
(command "_-purge" "a" "*" "N")
(setq CCC_Sheet "A1")
(command "updatefield" "all" "")
(command "regenall")
(command "_zoom" "e")
 (initdia)
 (command "._plot")
(PlotReactorON)
;(princ)
Thanks Bigal,
This is what I have but I get ; error: malformed list on input
(defun c:A1_All ()
(PlotReactorOFF)
       (command "_yes")
     ) ;_ while
     T
   ) ;_ progn
 ) ;_ if
(setq doc (vla-get-activedocument (vlax-get-acad-object)))
(vlax-for lay (vla-get-Layouts doc)
 (setq plotabs (cons (vla-get-name lay) plotabs))
(setq plottablist (acad_strlsort plotabs))
(setq len (length plottablist))
(setq x 0)
(repeat len
 (setq name (nth x plottablist))
 (princ name)
 (if (/= name "Model")
     (setvar "ctab" name)
 (initdia)
 (command "._plot")
(PlotReactorON)
;(princ)
Can you help?
At first glance, seems that you need a closing paranthesis for DEFUN; also you will need an indexer for page counter.
If you are looking to prevent the Model tab from beeing printed, then should place the printing actions inside the IF test.
[color=magenta]...[/color]
(repeat len
 (princ name)
   (initdia)
   (command "._plot")
   (PlotReactorON)
[color=red]   ) ;<- IF[/color]
[color=red]  )  ;<- PROGN[/color]
 ;(princ)
[color=red]  (setq x (1+ x))
[/color] )
[color=red])    ;<- DEFUN[/color]
Edited by MSasu
extra right paranthesis
If you don't mind, I will make another two comments: (1) try to indent the code while you write it, this way will be easier for you to match the parenthesis and statements enclosing; (2) in VL editor, when place the cursor outside a parenthesis and press + "[" or + "]" the cursor will move to the pair one, if don't move, then that parenthesis don't have a pair.
Freebie for any one interested a bracket checker
(defun c:chkbrk (/ opf bkt chekdfile rdctl wkfile currentln wln ltr ncln)
(setvar "cmdecho" 0)
(prompt "\nlook at end of line")
;(setq chekdfile (getstring "enter name of file :"))
(SETQ chekdfile (getfiled "Enter file name:" " " "LSP" 4))
(setq opf (open chekdfile "r"))
(setq bkt 0)
(setq blkl 0)
(setq rdctl 1)
(setq wkfile (open "c:\\acadtemp\\wow.lsp" "w"))
(setq currentln "a")
(while (/= blkl 6)
(setq currentln (read-line opf))
(if (= currentln nil)(setq currentln ""))
(if (= currentln "")(setq blkl (+ 1 blkl))(setq blkl 1))
(setq wln currentln)
(while (/= wln "")
       (setq ltr (substr wln 1 1))
       (setq wln (substr wln 2))
       (cond ((= (ascii ltr) 34) (if (= rdctl 0)(setq rdctl 1)(setq rdctl 0)))
               ((and (= ltr "(")(= rdctl 1))(setq bkt (+ bkt 1)))
               ((and (= ltr ")")(= rdctl 1))(setq bkt (- bkt 1)))
               ((and (= ltr ";")(= rdctl 1))(setq wln ""))
               ;(t (prompt ltr))
(setq ncln (strcat currentln ";" (itoa bkt)
(princ (itoa bkt))
(if (= rdctl 0) "string open" "")))
(if (/= currentln "")(write-line ncln wkfile))
(close wkfile)
(close opf)
(prompt (strcat "open brakets= " (itoa bkt) "."))
(setq ang1 nil
     pt1 nil
     pt2 nil
     pt3 nil
     pt4 nil
     pt5 nil)
Thanks Mircea but that doesn't seem to work either. I get an error
" ; error: extra right paren on input"
on running appload.
Did you notticed that is only an excerpt from your code?
But there was an extra right paranthesis, I have fixed that now.
Mircea,
I am still getting this error. Am i missing something? I copied the last lines of your updated code and replaced my code with them but when i go appload I get this.
; error: bad argument type: numberp: nil
Oh yeah, I got it now. Thanks.
