kamig Posted May 2, 2012 Share Posted May 2, 2012 hello bro, i am faceing problam regarding short command like i want to make trim i give TR its giving me NIL and when i give trim thats working fine so please help me???????? Quote Link to comment Share on other sites More sharing options...
vins1987 Posted May 2, 2012 Share Posted May 2, 2012 reload your pgp file by "reinit" command, if that doesn't work then reload your menu. Quote Link to comment Share on other sites More sharing options...
kamig Posted May 2, 2012 Author Share Posted May 2, 2012 bro i reinstall 2 time my cad but still same problam Quote Link to comment Share on other sites More sharing options...
jammie Posted May 2, 2012 Share Posted May 2, 2012 It sounds like you have associated TR with a lisp command. Have you any custom LISP routines loaded? Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 2, 2012 Share Posted May 2, 2012 (edited) We are talking about editing the acad.pgp file right? Reloading AutoCAD was overkill in this situation. Would you go out and buy four new tires for your car if only one was flat? Do you use any custom lisp routines? When you reinstalled AutoCAD did you edit the acad.pgp file? Edited May 2, 2012 by ReMark Quote Link to comment Share on other sites More sharing options...
dbroada Posted May 2, 2012 Share Posted May 2, 2012 I think jammie was probably closest. The NIL result is much more likely a LISP command than a missing pgp association. Quote Link to comment Share on other sites More sharing options...
kamig Posted May 2, 2012 Author Share Posted May 2, 2012 no sir i did not edit but when i found this file in floder that is all 0kb Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 2, 2012 Share Posted May 2, 2012 Your acad.pgp file shows up with a file size of 0kb? If you reinstalled AutoCAD MEP that seems near impossible. Are you sure you have the right folder? Quote Link to comment Share on other sites More sharing options...
kamig Posted May 2, 2012 Author Share Posted May 2, 2012 yes just now see that folder Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 2, 2012 Share Posted May 2, 2012 You must have deleted it then. How did you obtain your copy of the program? We are talking about AutoCAD MEP 2009 right? Quote Link to comment Share on other sites More sharing options...
kamig Posted May 2, 2012 Author Share Posted May 2, 2012 no i am working in Company and they Install for us Autocad 2010 when i face this problam then IT guy he install 2 time this same software for me but the same problam and this autocad copy this working other PC v fine only i have this problam when i give any short command like C, TR, CO, XR, MI if i give full command then working fine Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 2, 2012 Share Posted May 2, 2012 You know, it always helps to tell us exactly what program you're using when you are requesting assistance. Since you have another PC with AutoCAD 2010 on that is working fine then all you need to do is copy the acad.pgp file from that computer over to yours and put it in the AutoCAD 2010 Support folder. Sounds simple to me. IT could not figure this out on their own? Quote Link to comment Share on other sites More sharing options...
kamig Posted May 2, 2012 Author Share Posted May 2, 2012 no simple autocad 2010 Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 2, 2012 Share Posted May 2, 2012 Yes. Simple. Why would you think otherwise? Is this a network version of the program or a standalone version? Quote Link to comment Share on other sites More sharing options...
Dadgad Posted May 2, 2012 Share Posted May 2, 2012 ReMark is correct. Piece of cake to fix. Copy and paste the shortcall customizations that you need from one of the other stations running the same software, there is nothing to be gained by doing again, that which has twice failed to yield the desired effect. Meaning you don't need to install the program. You already have the standard shortcalls, what you need are the user customization files added, copied and pasted should do it. Quote Link to comment Share on other sites More sharing options...
kamig Posted May 2, 2012 Author Share Posted May 2, 2012 standalone version Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 2, 2012 Share Posted May 2, 2012 standalone version Copy from the computer where it works. Paste to the computer (yours) where it doesn't work. Make sure you put the file in the correct folder. If AutoCAD is already running issue the REINIT command then test. Done. You are making this more difficult than it needs to be. Quote Link to comment Share on other sites More sharing options...
kamig Posted May 2, 2012 Author Share Posted May 2, 2012 Yes bro i did it now it is fine thanks Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 2, 2012 Share Posted May 2, 2012 Yeah! At long last we have a success! See....it really wasn't that tough after all now was it? Quote Link to comment Share on other sites More sharing options...
jammie Posted May 2, 2012 Share Posted May 2, 2012 If REINIT does not work try the following LISP code (defun c:test () (setq bndCMD "" nonBndCmd "") (foreach <item> '("C:C" "C:TR" "C:CO" "C:XR" "C:MI") (if (boundp (read <item>)) (setq bndCMD (strcat bndCMD "\n" <item>)) (setq nonBndCmd (strcat nonBndCmd "\n" <item>)) ) ) (alert (strcat "\n*** Standard commands ***" nonBndCmd "" "\n*** LISP functions ***" bndCMD "" ) ) ) Quote Link to comment Share on other sites More sharing options...
