Results 1 to 4 of 4
    Full Member
    Civil 3D 2012
    May 2012
    77
    Default Rotated Image Disappears
    I've tried both draging an image into Autocad and importing it in as a block. When I try to rotates the image it either rotates around a point (but doesn't actually rotate itself) or rotates and disappears only leaving a white outline. How can I properly rotate an image?
    Super Member CyberAngel's Avatar
    CyberAngel's Computer Details
    Windows 10
    Architectural
    CyberAngel's Discipline Details
    Civil Drafter
    Architectural
    Roofing and Waterproofing
    AutoCAD 2014
    Jul 2006
    Anywhere Else
    1,178
    Have you tried using the Xref Manager to insert the image? How about pasting it as an OLE object? Those are the recommended options.
    breaking AutoCAD on a regular basis since 1991
    Full Member
    Civil 3D 2012
    May 2012
    77
    I did try pasting the image into its own drawing and referencing that drawing using the Xref manage, but it didn't work. How do I paste the image in as an OLE object?
    EDIT: I figured it out. To do this copy the image, click on home tab -> paste (on clipboard area) -> paste special, then click 'image entity'. That's the only option I've found that allows for proper rotation.
    Thanks for your help.
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,952
    You need to use IMAGEATTACH (INSERT>RASTER IMAGE REFERENCE)
    OLE objects cannot be rotated.
  1. UCS rotated?
    By ServaCleanCAD in forum AutoCAD Beginners' Area
    Last Post: 7th Jul 2010, 09:35 am
  2. Rotated UCS leads to rotated Reference Files
    By BenGoble in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 12th Apr 2010, 01:01 pm
  3. Rotated Ucs Problem
    By Dipali in forum AutoCAD General
    Last Post: 16th May 2008, 03:40 am
  4. Rotated Viewport
    By Skeeps in forum AutoCAD Drawing Management & Output
    Last Post: 10th Oct 2006, 09:53 am
  5. rotated WCS
    By Barry Clark in forum AutoCAD 3D Modelling & Rendering
    Last Post: 17th Sep 2004, 04:36 pm
Tags for this Thread
