Results 1 to 2 of 2
Thread: Spline ISSUE
    Forum Newbie
    not applicable
    Oct 2012
    Question Spline ISSUE
    I'm using SolidWorks 2012 and when I'm trying to sketch the basic spline, the Spline Points feature is innactive. So, basically, I cannot draw it in the way I need to.
    Screenshot is attached.
    How to make it active ?
    Any ideas ?
    Inventor 2015
    Sep 2007
    Williamsport, PA
    Place and dimension locations of sketch points.
    Now create your spline to the sketch points.
  1. Spline tangent problem - Spline on path of circles
    By the_system in forum AutoCAD General
    Last Post: 24th Oct 2011, 04:09 pm
  2. Model scale / VP scale issue / Co-ordinates issue
    By Richard Radford in forum AutoCAD Beginners' Area
    Last Post: 26th Aug 2010, 11:16 am
  3. spline to arc
    By todorb2000 in forum AutoLISP, Visual LISP & DCL
    Last Post: 23rd Sep 2008, 09:38 pm
  4. Spline issue
    By ulubilge in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 5th May 2008, 07:45 pm
  5. Spline
    By yeva in forum AutoCAD Beginners' Area
    Last Post: 15th Mar 2007, 06:34 pm
Tags for this Thread
